Use of extension cord?
jchas41
jchas41 Posts: 84
I recently purchased a Pioneer Elite 54-TX, and unfortunately it does not fit in the custom shelf that is sold with my TV. In my TV shelf I have my dvd player, satellite box and power center. My problem now is that due to room constraints I had to put my "Receiver rack" a bit out of the way. I now need an extension cable to reach my power center. Any recommendations? Is this going to negatively impact my recievers performance? The 54-TX does not have a detachable power cable either. Thanks for your help.
My Set-Up:
Sharp LC60E88UN- Display
Yamaha RX-A2020- A/V Receiver
Pioneer Elite BDP-23FD Bluray Player
Toshiba HD-A2 HD-DVD Player
Velodyne DPS-12 - Sub
Polk RTi8's- Fronts
Polk CSi5 - Center Channel
Polk FXi A4's- rear surrounds
Monster HTS2600 Line Conditioner
PS4
Post edited by jchas41 on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    If you get an extension cable for it, make sure it is at least 12 gauge(even 10 gauge would be okay).
    Tschüss
    Zach
  • jchas41
    jchas41 Posts: 84
    edited January 2005
    Can you make a brand recommendation or provide a link? Thanks alot.
    My Set-Up:
    Polk RTi8's- Fronts
    PS4
  • okiepolkie
    edited January 2005
    Something like this would probably work(lengths are at your discretion:
    10 gauge
    or
    12 gauge
    or
    parts express
    I don't know if these are what you are looking for, but I think any of them will compliment the existing wiring in your house.
    Tschüss
    Zach
  • jchas41
    jchas41 Posts: 84
    edited January 2005
    Okay thanks a lot. That is a big help.:)
    My Set-Up:
    Polk RTi8's- Fronts
    PS4
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2005
    Why not fabricate one yourself? It'll be cheaper and probably better...
