Parasound A23 and 1c’s ......
gyosa
gyosa Posts: 770
So , I’ve decided that I need a new amp to drive either my new Salks or my Sda 1c’s...
Currently driving my sda 1c’s with a parasound A21 , and it does a fine job ...
Found a 1 year old A23 locally for $500....
Anyone here have any experience using an a23 on 1c’s and what are your thoughts ?
Or, I could use the A23 on the salks .
I also have a EX-442 - but it is currently driving my patio rig....
Anyone have any thoughts ?
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • DaveHo
    DaveHo Posts: 3,583
    I'd put the B&K on the 1Cs and find a new amp for the patio rig.
  • rooftop59
    rooftop59 Posts: 8,121
    edited May 2019
    DaveHo wrote: »
    Agree...the b&k should have plenty of power and it’s overkill for a patio rig imho...I mean 75A peak current for a patio rig?!?
    Game Room 5.1.4:
    Bedroom 2.1
  • Emlyn
    Emlyn Posts: 4,719
    An A23 isn't really enough to get the best out of a pair of 1Cs. But at that price it may be worth picking up just to have around and work with.
  • gyosa
    gyosa Posts: 770
    edited May 2019
    I’ve had the 442 since new ....
    Bought it for the 1c’s - used it for years on them .... fantastic combination
    It got moved to patio/pool rig when I got the A21 .....
    The 1c’s are the bedroom rig now on the A21..
    The Salks are going in the den to replace klipsch kg4’s which are hooked up to a onkyo tx-rz610 AVR (100 watts on 2 ch only , and not 4 ohm stable) doing light 2 channel duty for music and TV.
    So , I obviously don’t want to power the Salks with an AVR .... hence the need for a new amp ...
    I don’t think the onkyo will drive my patio / pool Boston acoustics voyager 7’s to acceptable volume levels without distortion... I guess I could try it ...
    The A21 is a bit too large for the den’s media cabinet and the wife doesn’t want to look at it .... was going to either remove the rear handles on amp or modify the cabinet.
    Wonder if the A23 is enough for the Salks ?
    Or maybe the 442 for the Salks , leave a21 for 1c’s and a23 for patio ?
    Problem is mid level AVR’s suck for anything other than light duty and we spend a lot of time in pool .... AND the patio rig sounds REALLY good with the 442 ...
    Bk
