Budget 2CH Rig for Newbies - A Challenge
That's awesome! Nice bunch of rigs you got there buddy! You're probably like me, always looking around to find the deal! Part of the journey, and fun! Welcome to CP!
Thanks Verb. The journey and the listening and the deals make me smile in this chaotic world. -
StevePaige wrote: »
Right on! Hang out here, especially the classifieds, and you'll find some smoking deals on really top notch stuff! I know I did. Basement is starting to fill up!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So my buddy is back in the game, as he texted me for suggestions on a power amp today. Found these minty Adcom GFA 545 mono blocks for $160 each! Seems like a good deal! What'cha think?
https://detroit.craigslist.org/mcb/ele/d/vassar-adcom-gfa-545-power-amps-2-avail/6872672417.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I was under the impression that they were 2 channels, there could be a monoblock version but I am not aware of it.
I have one of these and they power my SDA 2Bs without breaking a sweat. Can't tell if they are a Mk1 or 2. I have the Mk1 but some people fight over which is the better model.
They have no speaker protection so if they haven't been recapped and serviced that would be the first thing I would do to avoid any issues with the amp kicking the dust and taking the speakers with it.
Some attribute these amps to being bright, that hasn't been my experience. I run them with a vintage Denon Preamp. Some say if you pair them with the lower/mid Adcom GFP Preamps that they sound grainy and clinical. Either way they have FANTASTIC control over bass and loads of it.
I bought my GFA for $120...recapped.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I think you are correct. 2 channels each amp, he just has 2 of em! Even better deal for my buddy!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
They are nice forays into decent mid-fi amps. I like mine and currently am not in a rush to get something different. Tell him to keep fuses on standby, I have made mistakes and blown a couple on each channel.
Probably a good idea to test DC offset as well since there is a lack of protection.Just a dude doing dude-ly things
Thanks brother. DC offset? Not sure what that means! Help a brother out!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Of course. A channel can develop more DC than the other. Usually amp manufacturers have a certain spec and threshold that is considered "good", I have read anything below 100mv is good enough.
To check you have to use a multimeter and turn the amp on with sources connected but speakers disconnected. Connect the ground of the multimeter to the ground terminal post and hot to hot. Read the output. Let the amp sit idle for 10 min plus so it gets up to normal operating status before you test. Repeat the same for the second channel.
Now I can't remember the setting on the multimeter you need to set it to but I'm sure someone will chime in.Just a dude doing dude-ly things
Reason this is so important in your scenario is Adcoms lack of speaker protection is lack of protecting the speakers from DC which will fry them faster than a Turkey on thanksgiving.
Some other issues DC offset can cause is channel imbalance, one side of the amp getting hotter than the other which can lead to a failing cap.Just a dude doing dude-ly things
Thank you sir! I can do that! And interesting. Learn something new every day on CP!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
No problem dude. I don't know much but happy to give what information or experiences I have.Just a dude doing dude-ly things
I am late to this thread... but I have a Dared Sl200 preamp I got from Paul, then gave it back and bought my own as many Polkies have own and loved! then I added some Dared Monoblocks the VP-300B's together I got them for $800
they only put out 9 WPC but for high efficiency speakers they made a sweet system with my full range speakers.
but you can use the preamp with some cheaper amplifiers that hit at 100-150 WPC in the same price range and start a wonderful preamp + amp combo that will shove you straight down the rabbits hole to a none stop life of trying to keep up with the jones that will take over your wallet to the ruin of you $$$ but to the love of your audiophile ears2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Maybe something along these lines?
Nice! I did recommend some of the Parasound items to my buddy. Especially previous gen, which can be had for a bargain!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I really enjoy them, very well voiced and plenty of power, a pleasure to listen, I have to thank this forum for that!
I would grab the newer JC top of the line stereo amps in a hearth breath...too -
Heh -- thanks to the kindness of one of the northern New England vacuum tube hifi gurus, I have the tuner that matches those Parasound components.
It is a remarkably respectable tuner, actually, in terms of both RF and AF performance.
(FWIW)
Nice! I am a radio listener and that tuner is on my list!
mhardy6647 wrote: »Heh -- thanks to the kindness of one of the northern New England vacuum tube hifi gurus, I have the tuner that matches those Parasound components.
(FWIW)
What model tuner is that from Parasound?2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp) -
Looks like a T/DQ1600
I think that's correct -- I actually went back to using the MR-67 (underneath the Parasound in the photo above) a few months ago, so the Parasound's leaning up in the corner by a pair of AR-3s I will check next time I go upstairs, FWIW.
Someone I know picked it up for $5 at a local (to him) yard sale. Saying "you like tuners", he subsequently passed it along to me. It's nice to have enabling acquaintances
I was, frankly, surprised by how "hot" (sensitive) it was and by its better than average (for solid state tuners) audio quality. It is a very decent tuner by any reasonable standard.
The MR-67 does sound better, but it was rather more expensive
You know I see those models for sale ALL the time in my area. Never heard them though.Just a dude doing dude-ly things
My buddy was all excited today, and I for him! He purchased a B&K ST1400 Mk2 Amp! Stock image.
Oh Lordy! Now on 2 threads!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
codycatalist wrote: »You know I see those models for sale ALL the time in my area. Never heard them though.
Honestly I found them a little thin and sterile sounding. Definitely plenty of power, but the bass seemed a little weak and they just didn’t sound as musical as the (relatively cheap) adcom and audiosource amps I had at the time. Imho of course...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Which is odd for Marantz. I figured something had to be up for so many to be out in the wild for low prices.Just a dude doing dude-ly things
codycatalist wrote: »codycatalist wrote: »You know I see those models for sale ALL the time in my area. Never heard them though.
Yea, but they were early home theater amps from the mid to late 90s. While they measured well, and have plenty of power, they just don't seem to have been designed with audio first in mind...
On the other hand, I really like my little marantz avr, and find it more musical though limited in the typical mid range avr ways...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Looks like a T/DQ1600mhardy6647 wrote: »Looks like a T/DQ1600
Thanks for the info!2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
