Budget 2CH Rig for Newbies - A Challenge
124»
  • StevePaige
    verb wrote: »
    That's awesome! Nice bunch of rigs you got there buddy! You're probably like me, always looking around to find the deal! Part of the journey, and fun! Welcome to CP! :smile:
    Thanks Verb. The journey and the listening and the deals make me smile in this chaotic world.
  • verb
    verb Posts: 10,176
    StevePaige wrote: »
    verb wrote: »
    Right on! Hang out here, especially the classifieds, and you'll find some smoking deals on really top notch stuff! I know I did. Basement is starting to fill up! :smile:
  • verb
    verb Posts: 10,176
    So my buddy is back in the game, as he texted me for suggestions on a power amp today. Found these minty Adcom GFA 545 mono blocks for $160 each! Seems like a good deal! What'cha think?
    https://detroit.craigslist.org/mcb/ele/d/vassar-adcom-gfa-545-power-amps-2-avail/6872672417.html
  • codycatalist
    codycatalist Posts: 2,661
    edited April 2019
    verb wrote: »
    I was under the impression that they were 2 channels, there could be a monoblock version but I am not aware of it.
    I have one of these and they power my SDA 2Bs without breaking a sweat. Can't tell if they are a Mk1 or 2. I have the Mk1 but some people fight over which is the better model.
    They have no speaker protection so if they haven't been recapped and serviced that would be the first thing I would do to avoid any issues with the amp kicking the dust and taking the speakers with it.
    Some attribute these amps to being bright, that hasn't been my experience. I run them with a vintage Denon Preamp. Some say if you pair them with the lower/mid Adcom GFP Preamps that they sound grainy and clinical. Either way they have FANTASTIC control over bass and loads of it.
    I bought my GFA for $120...recapped.
  • verb
    verb Posts: 10,176
    I think you are correct. 2 channels each amp, he just has 2 of em! Even better deal for my buddy! :smile:
  • codycatalist
    verb wrote: »
    They are nice forays into decent mid-fi amps. I like mine and currently am not in a rush to get something different. Tell him to keep fuses on standby, I have made mistakes and blown a couple on each channel.
    Probably a good idea to test DC offset as well since there is a lack of protection.
  • verb
    verb Posts: 10,176
    Thanks brother. DC offset? Not sure what that means! Help a brother out! :smile:
  • codycatalist
    Of course. A channel can develop more DC than the other. Usually amp manufacturers have a certain spec and threshold that is considered "good", I have read anything below 100mv is good enough.
    To check you have to use a multimeter and turn the amp on with sources connected but speakers disconnected. Connect the ground of the multimeter to the ground terminal post and hot to hot. Read the output. Let the amp sit idle for 10 min plus so it gets up to normal operating status before you test. Repeat the same for the second channel.
    Now I can't remember the setting on the multimeter you need to set it to but I'm sure someone will chime in.
  • codycatalist
    Reason this is so important in your scenario is Adcoms lack of speaker protection is lack of protecting the speakers from DC which will fry them faster than a Turkey on thanksgiving.
    Some other issues DC offset can cause is channel imbalance, one side of the amp getting hotter than the other which can lead to a failing cap.
  • verb
    verb Posts: 10,176
    Thank you sir! I can do that! And interesting. Learn something new every day on CP! :smile:
  • codycatalist
    No problem dude. I don't know much but happy to give what information or experiences I have.
  • voltz
    voltz Posts: 5,384
    I am late to this thread... but I have a Dared Sl200 preamp I got from Paul, then gave it back and bought my own as many Polkies have own and loved! then I added some Dared Monoblocks the VP-300B's together I got them for $800
    they only put out 9 WPC but for high efficiency speakers they made a sweet system with my full range speakers.
    but you can use the preamp with some cheaper amplifiers that hit at 100-150 WPC in the same price range and start a wonderful preamp + amp combo that will shove you straight down the rabbits hole to a none stop life of trying to keep up with the jones that will take over your wallet to the ruin of you $$$ but to the love of your audiophile ears >:)
  • cortico
    cortico Posts: 592
    Maybe something along these lines?
  • verb
    verb Posts: 10,176
    Nice! I did recommend some of the Parasound items to my buddy. Especially previous gen, which can be had for a bargain! :smile:
  • cortico
    cortico Posts: 592
    edited April 2019
    verb wrote: »
    I really enjoy them, very well voiced and plenty of power, a pleasure to listen, I have to thank this forum for that!
    I would grab the newer JC top of the line stereo amps in a hearth breath...too :)
    mhardy6647 Posts: 35,555
    edited April 2019
    Heh -- thanks to the kindness of one of the northern New England vacuum tube hifi gurus, I have the tuner that matches those Parasound components.
    It is a remarkably respectable tuner, actually, in terms of both RF and AF performance.
    (FWIW)
  • cortico
    cortico Posts: 592
    Nice! I am a radio listener and that tuner is on my list!
  • HzTweaker
    HzTweaker Posts: 1,122
    (FWIW)
    What model tuner is that from Parasound?
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
  • cortico
    cortico Posts: 592
    Looks like a T/DQ1600
    edited May 2019
    cortico wrote: »
    I think that's correct -- I actually went back to using the MR-67 (underneath the Parasound in the photo above) a few months ago, so the Parasound's leaning up in the corner by a pair of AR-3s :p I will check next time I go upstairs, FWIW.
    Someone I know picked it up for $5 at a local (to him) yard sale. Saying "you like tuners", he subsequently passed it along to me. It's nice to have enabling acquaintances :|
    I was, frankly, surprised by how "hot" (sensitive) it was and by its better than average (for solid state tuners) audio quality. It is a very decent tuner by any reasonable standard.
    The MR-67 does sound better, but it was rather more expensive B)
  • codycatalist
    You know I see those models for sale ALL the time in my area. Never heard them though.
  • verb
    verb Posts: 10,176
    My buddy was all excited today, and I for him! He purchased a B&K ST1400 Mk2 Amp! Stock image.
  • verb
    verb Posts: 10,176
  • rooftop59
    rooftop59 Posts: 8,120
    Honestly I found them a little thin and sterile sounding. Definitely plenty of power, but the bass seemed a little weak and they just didn’t sound as musical as the (relatively cheap) adcom and audiosource amps I had at the time. Imho of course...
    Game Room 5.1.4:
    Bedroom 2.1
  • codycatalist
    rooftop59 wrote: »
    Which is odd for Marantz. I figured something had to be up for so many to be out in the wild for low prices.
  • rooftop59
    rooftop59 wrote: »
    Yea, but they were early home theater amps from the mid to late 90s. While they measured well, and have plenty of power, they just don't seem to have been designed with audio first in mind...
    On the other hand, I really like my little marantz avr, and find it more musical though limited in the typical mid range avr ways...
    Game Room 5.1.4:
    Bedroom 2.1
  • HzTweaker
    cortico wrote: »
    cortico wrote: »
    Thanks for the info!
