FS: Odyssey Audio Stratos Extreme Stereo Amplifier
VR3
Will post more pics soon.
I would rate this 7/10 give or take. No real major marks, but enough minor ones to rate it conservatively. Not even sure I could photograph it, but on the edges you can see some marks and such. Any distance over 18" the amp looks very very good.
Dual transformers, loads of storage. A true beast of an amplifier. Stable to 2 ohms.
Not quite a Kismet, but close! :-)
$1000 shipped with paypal with original box and packing
Specs per Odyssey site -
Stratos Stereo:
base model specifications:
$1,375 USD
2 x 150 Watts RMS @ 8 Ohms
2 Ohm load stable
Class A/AB
2 - 400,000 Hz frequency range
60,000µF memory
45 amps current delivery
<0.04% THD (not audible)
>500 continuous damping factor
Input impedance 22K ohms
DC offset <1 mV
RCA & XLR (bridged) inputs
400 VA Plitron transformer
Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
Anti vibration dual thickness PCB
Power consumption when idle ±30Watts
4 internal fuses 250V/6.3A, 5x20mm, fast blow
Additional electrical protection fuse
54 lbs weight / 24.5 kg
Dimensions: 19 width x 18 deep x 7 height (in) /
48.3 width x 45.7 deep x 17.8 height (cm)
Stratos Stereo Plus:
improvements over base model:
$ 1,500 USD
Additional 60,000µF memory bank for 120,000µF total
55 lbs / 25 kg weight
Stratos Stereo Extreme:
improvements over Plus model:
$ 1,800 USD
Additional 60,000µF memory bank for 180,000µF total
>60 amps current delivery
Additional 400 VA Plitron transformer for 800VA total
Power consumption when idle ±35Watts
70 lbs / 32 kg weight
Stratos Stereo:
$1,375 USD
2 Ohm load stable
Class A/AB
60,000µF memory
DC offset <1 mV
$ 1,500 USD
$ 1,800 USD
Man I imagine that thing is a beast!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
PM sent.
Sold!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
@indyhawg I'm glad you snagged that amp! As I just got the McCormack, well you know!
Thanks, @verb. Looking forward to hearing this amp in my system. Still interested in your take on the McCormack.
So Trey, Jim, James not Tom with all the upgrades is this still considered 150wpc?
Nice Jeff wish I was closer to come get my ears on it. -
I believe the extreme comes. In around 180? It's really the fact it can dip to 2 ohms, tons of current- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Got it.
Amp arrived today exactly as described. Appreciate the quick shipment Trey.
excellente!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
