FS: Odyssey Audio Stratos Extreme Stereo Amplifier
VR3
VR3 Posts: 29,580
edited April 2019 in For Sale (FS) Classifieds
Will post more pics soon.
I would rate this 7/10 give or take. No real major marks, but enough minor ones to rate it conservatively. Not even sure I could photograph it, but on the edges you can see some marks and such. Any distance over 18" the amp looks very very good.
Dual transformers, loads of storage. A true beast of an amplifier. Stable to 2 ohms.
Not quite a Kismet, but close! :-)
$1000 shipped with paypal with original box and packing
Specs per Odyssey site -
Stratos Stereo:
base model specifications:
$1,375 USD
2 x 150 Watts RMS @ 8 Ohms
2 Ohm load stable
Class A/AB
2 - 400,000 Hz frequency range
60,000µF memory
45 amps current delivery
<0.04% THD (not audible)
>500 continuous damping factor
Input impedance 22K ohms
DC offset <1 mV
RCA & XLR (bridged) inputs
400 VA Plitron transformer
Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922
Anti vibration dual thickness PCB
Power consumption when idle ±30Watts
4 internal fuses 250V/6.3A, 5x20mm, fast blow
Additional electrical protection fuse
54 lbs weight / 24.5 kg
Dimensions: 19 width x 18 deep x 7 height (in) /
48.3 width x 45.7 deep x 17.8 height (cm)
Stratos Stereo Plus:
improvements over base model:
$ 1,500 USD
Additional 60,000µF memory bank for 120,000µF total
55 lbs / 25 kg weight
Stratos Stereo Extreme:
improvements over Plus model:
$ 1,800 USD
Additional 60,000µF memory bank for 180,000µF total
>60 amps current delivery
Additional 400 VA Plitron transformer for 800VA total
Power consumption when idle ±35Watts
70 lbs / 32 kg weight
  • verb
    verb Posts: 10,176
    Man I imagine that thing is a beast! :smile:
    VR3 Posts: 29,580
    Sold!
  • verb
    verb Posts: 10,176
    @indyhawg I'm glad you snagged that amp! As I just got the McCormack, well you know! :smile:
    audioluvr Posts: 5,997
    indyhawg wrote: »
    PM sent.
    Nice score!
  • indyhawg
    indyhawg Posts: 1,676
    edited April 2019
    Thanks, @verb. Looking forward to hearing this amp in my system. Still interested in your take on the McCormack.
    pitdogg2 Posts: 27,442
    So Trey, Jim, James not Tom with all the upgrades is this still considered 150wpc?
    Nice Jeff wish I was closer to come get my ears on it.
    VR3 Posts: 29,580
    I believe the extreme comes. In around 180? It's really the fact it can dip to 2 ohms, tons of current
  • indyhawg
    Amp arrived today exactly as described. Appreciate the quick shipment Trey.
    VR3 Posts: 29,580
    excellente!
