Polk Command Bar Alexa Offline
mauricecf
Alexa is offline almost everyday since I bought the Command Bar a week ago. I have to reset it every time via Polk app. When I do the reset if doesn’t even show the Command Bar in the app. What’s the point of having Alexa integration when Alexa doesn’t even work. The sound works with my TV. It’s just Alexa. Any fix? If not I’m returning to Best Buy and buying a different brand and Echo Dot.
You aren’t cheating on her with Siri, are you? Alexa tends to be just a bit jealous....
J/k... hopefully Ken Swauger will see your post and get it to the right people at Polk to help out.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Let me bring this to Polk's attention.
I really want to keep my Command Bar, but this problem is a make it or break it.
Also, is there anyway the wake word can change. I got an Alexa in my life lol -
I'm having the same issue...it seems that if I lose internet connection (which happens sometimes) I have to reset Alexa through the Polk app. It is getting annoying. The Amazon Echo will automatically reconnect when I lose connection. Please any assistance would be appreciated.
I am having the same issue with having to reset the command bar frequently. We always lose sound from the soundbar when changing from TV to Amazon or Netflix, etc. I have always been able to reset and get Alexa back but now it's offline and I can't get it reconnected. The bar is only 2 months old.
The CIA will look into it.. .
You're both wrong, it's the NSA that listens and listen they do.Political Correctness'.........defined
President of Club Polk -
Same problem. Got Command Bar a few days ago, but it loses wifi connection at least once or sometimes more per day. No problem with other devices on wifi. Command Bar reconnects if I just unplug it and plug it in again. This is ridiculous!
Same problem..Polk obviously did not integrate Alexa properly and shame on Polk for keeping us in the dark on solution(s) while marketing a defective technology
Same problem.
Also it mutes when the Echo Show is in use
This also happens to mine also, unfortunately it’s to late to take back to Best Buy. Does the warranty cover this. I am sick of it.
Smartphones can check e-mail, record videos and even stream NPR. Now NASA has discovered they make pretty decent satellites, too. ... The PhoneSats started as a project among young engineers working at the NASA Ames Research Center in California. Jim Cockrell, the project's manager, says it began as a hallway conversation.You're both wrong, it's the NSA that listens and listen they do.Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Spammer reported
