Can Polk SDS SRS be upgraded to a 1.2TL?
Just curious if a set of Can Polk SDS SRS be upgraded to a 1.2TL and is it worth it or would I be better off just looking for a set of TL's
Home Theater & Listening
RECEIVER Yamaha HTR6180
FRONT AMP McIntosh MC2125
THEATER AMP EMOTIVA XPA 7
FRONT Polk SDA 1B
CENTER Polk CsiA4
SURROUND LR KEF Cresta 30
REAR Polk Monitor 5
SUB Tannoy TS 10 Subwoofer
NAS 20 TB Raid 3 QNAP
Office
AMP Luxman L210
SPEAKERS Tannoy
    nooshinjohn Posts: 26,001
    edited April 2019
    I suppose if you wanted to , the original SRS can be upgraded, but the only thing you could use from them would be the passive radiators., and I am not even certain on that. Best to look for a set of TL’s, or upgrade the tweeters to RDO 194’s and do the crossovers in what you have.
  • ZaPHoN
    ZaPHoN Posts: 90
    Gotcha. Sorry for the re-post. I didn't see this topic already covered in an older thread.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • verb
    verb Posts: 10,176
    That is my plan! Already upgraded the tweeters, XO's on the list! :smile:
  • sbb2112
    sbb2112 Posts: 134
    I may someday hunt down a set of 1.2s but I have about 500 hours on my SRS’s that are completely modded and running vr3 crossovers. They are bad to the bone. I would think twice before frankensteining a good set of SRS’s. Just upgrading the original or passing them on and getting a set of 1.2s would be the best play
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    F1nut Posts: 52,005
    They still wouldn't be 1.2TL's as the cabinets are built differently.
  • ZaPHoN
    ZaPHoN Posts: 90
    edited April 2019
    Doing some research from images here I can see the internal construction is significant. The TL's are a lot more open between the drivers. Mine have solid panel with a square hole between each level.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
    pitdogg2 Posts: 27,325
    ZaPHoN wrote: »
    I believe they are also different cabinet material as well.
    F1nut Posts: 52,005
    Different bracing, different material and different internal wall design.
