DIY Pedicab sound system. Looking for some help!
nooshinjohn wrote: »Any chance your license plate reads "UBUYGAS"?
LOL
since your peddling all over the country, better get a heater while your at it, and snow tires.HT SYSTEM-
lsi 9's -
@nooshinjohn you nailed it.
UPDATE: Cancel that on buying a separate battery. Just got the green light from they guy building my pedicab that using a 30ah 48v to 12v converter will work just fine.
Buying this one. It's much more well built than the other crap on Amazon:
https://www.amazon.com/Reliance-Golf-Cart-Voltage-Converter/dp/B079Q2QPGW/ref=sxbs_sxwds-stvp?crid=1HHUD5X1JGG0D&keywords=48v+to+12v+converter&pd_rd_i=B079Q2QPGW&pd_rd_r=a9df5587-dc0e-492d-9914-852c070f2985&pd_rd_w=ofkJ6&pd_rd_wg=aJBO1&pf_rd_p=5c5ea0d7-2437-4d8a-88a7-ea6f32aeac11&pf_rd_r=W1Y66BZDZN6HQJ8SVXJN&qid=1553747892&s=gateway&sprefix=48v+,aps,156
Appreciate everyone's help with all this. The Polk 3 way 6x9's with the Kenwood amp are bumping. Not much draw on my battery either.
Hey I see your pedicab and am wondering if you built it or bought it. I have been looking to buy or make one just like yours but haven't had any luck so far. Could you please advise on how and where you got the one in the pic. Thanks
Will
