RTi A9 Questions
Hi,
I paired these with a Marantz SR5013 (100wpc@8 ohms) hoping that would be enough power. I am bi-amping the A9's.
What is the consensus on power requirements? These sound fantastic when is HT mode, but 2-channel stereo doesn't sound as good as I had expected. Part of it is I'm in a completely new room and am still figuring out the acoustics. I'm coming from some very old RT8's, which are now my surrounds. I have a powered Polk subwoofer as well.
Do I really need to add a power amp to this setup? If so, how much power do I really need?
Thanks,
Dan
Thanks,
Dan
Do you have a subwoofer? And are your A9's crossed over to either 80hz or lower?
The woofs on the A9 will suck power like no other. If you are running large, you will want to feed them with as much power as you can.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
The 9s need power. Look for an amp around 200w per channel to go with your Marantz.
Also you aren’t really bi- amping them. You are using the same power supply. It’s a marketing hoax manufacturers use.
Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
Patio- SDI Atrium8 x3, Emotiva A-100 amps x3 -
Yes, I have a sub and the A9's are crossed over @ 80hz. I've gone ahead and ordered a Parasound 2250. Hopefully, that should be enough juice, lol.
Dan
Dan
Nicely done! Yeah, you'll be fine. The real need for power is feeding the woofers, since you're crossed over at 80 and running a sub to do the big stuff, your A9's won't require that much power.
I'm currently NOT running my subs and have my A9's at full band. When the LFE digs in deep, I'm very grateful for the extra power supplied from my amps.Set up: 11.2 HT + 2ch
I cross my A9s at 60hz with subs. I have seen people that cross them at 40hz. Watch the volume dial if you do.Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
Got the Parasound hooked up and, I gotta say, I was skeptical that it would make that much of a difference. However, the A9's went from lifeless, flat sounding 2 dimensional speakers to very clear, clean 3-dimensional speakers. I'm amazed at the difference. In hindsight, I probably should have got the A7's because it would have been much less expensive, but these do sound awesome with the amp, so I guess I'll go enjoy them now.
Dan -
Congrats...glad the amp is working out for you.HT SYSTEM-
lsi 9's -
Dan
I would love to hear some 9s properly powered like that. Congrats! Have you tried running them full range with that amp? Seems like a waste to me to cross them over when they can hit 30hz with enough clean power, which you now should have...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Dan
Nice! The 9s love that power.
I swear cookie monster designed that speaker. The more you give them the happier they are.Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
Dan
Full range, no crossover. They sound fantastic this way, and the amp doesn't even get warm.
Dan -
Full agreement!!
Dan
And they play well with subs!
