RTi A9 Questions
Hi,
I paired these with a Marantz SR5013 (100wpc@8 ohms) hoping that would be enough power. I am bi-amping the A9's.
What is the consensus on power requirements? These sound fantastic when is HT mode, but 2-channel stereo doesn't sound as good as I had expected. Part of it is I'm in a completely new room and am still figuring out the acoustics. I'm coming from some very old RT8's, which are now my surrounds. I have a powered Polk subwoofer as well.
Do I really need to add a power amp to this setup? If so, how much power do I really need?
Thanks,
Dan
  • Geoff4rfc
    Geoff4rfc Posts: 2,837
    Do you have a subwoofer? And are your A9's crossed over to either 80hz or lower?
    The woofs on the A9 will suck power like no other. If you are running large, you will want to feed them with as much power as you can.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • dolbyd
    dolbyd Posts: 430
    The 9s need power. Look for an amp around 200w per channel to go with your Marantz.
    Also you aren’t really bi- amping them. You are using the same power supply. It’s a marketing hoax manufacturers use.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • dcumpian
    dcumpian Posts: 4
    Yes, I have a sub and the A9's are crossed over @ 80hz. I've gone ahead and ordered a Parasound 2250. Hopefully, that should be enough juice, lol.
    Dan
  • Geoff4rfc
    dcumpian wrote: »
    Dan
    Nicely done! Yeah, you'll be fine. The real need for power is feeding the woofers, since you're crossed over at 80 and running a sub to do the big stuff, your A9's won't require that much power.
    I'm currently NOT running my subs and have my A9's at full band. When the LFE digs in deep, I'm very grateful for the extra power supplied from my amps.
    Set up:
  • dolbyd
    dolbyd Posts: 430
    I cross my A9s at 60hz with subs. I have seen people that cross them at 40hz. Watch the volume dial if you do.
  • Geoff4rfc
    dolbyd wrote: »
    guilty as charged B)
    Set up:
  • dcumpian
    dcumpian Posts: 4
    Got the Parasound hooked up and, I gotta say, I was skeptical that it would make that much of a difference. However, the A9's went from lifeless, flat sounding 2 dimensional speakers to very clear, clean 3-dimensional speakers. I'm amazed at the difference. In hindsight, I probably should have got the A7's because it would have been much less expensive, but these do sound awesome with the amp, so I guess I'll go enjoy them now. ;)
    Dan
    tonyb Posts: 33,072
    Congrats...glad the amp is working out for you.
  • rooftop59
    rooftop59 Posts: 8,121
    dcumpian wrote: »
    Dan
    I would love to hear some 9s properly powered like that. Congrats! Have you tried running them full range with that amp? Seems like a waste to me to cross them over when they can hit 30hz with enough clean power, which you now should have...
    Game Room 5.1.4:
    Bedroom 2.1
  • dolbyd
    dolbyd Posts: 430
    dcumpian wrote: »
    Dan
    Nice! The 9s love that power.
    I swear cookie monster designed that speaker. The more you give them the happier they are.
  • dcumpian
    dcumpian Posts: 4
    rooftop59 wrote: »
    dcumpian wrote: »
    Dan
    Full range, no crossover. They sound fantastic this way, and the amp doesn't even get warm.
    Dan
  • Geoff4rfc
    dolbyd wrote: »
    Full agreement!!
    dcumpian wrote: »
    Dan
    And they play well with subs!
    Set up:
