Weight, body, and heft
What elements of a stereo system contribute toward the sound having a palpable weight or body to it?
Thick (but not syrupy), lush, organic, full bodied sound with some good meat on it's bones. The opposite of thin or anemic sound.
Just wondering if there's some obvious things that would contribute to this audible sensation. A speaker with a dedicated midrange driver? A certain brand of speaker? Vinyl vs digital? Certain tubes or cables? Certain types of room treatments?
    nooshinjohn Posts: 25,985
    Everything matters, from cables to choice of music. From your source to your speakers... nothing is more or less important.
  • displayname
    displayname Posts: 1,232
    Clipdat wrote: »
    So many things in the system contribute to the overall sound. But when you listed this specific series of descriptions, the main thing that came to my mind is good quality bass. How you get there is a winding road with a million routes, but when I hear those key words, good bass is what comes to mind. Not always necessarily deep, just very well produced.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
  • BlueFox
    BlueFox Posts: 15,250
    +1
  • MrBuhl
    MrBuhl Posts: 2,419
    When you talk weight or body, I agree everything matters, period.
    I also agree about bass in the sense that there has to be a flow or balance, without great blending of the low and low-mid, there will be no "palpable weight", life all about balance Daniel-san.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • JPete
    JPete Posts: 298
    Room, room treatments, speakers, and speaker placement generate the most obvious differences in weight of the sound to me. Of course associated equipment makes a difference, and what works in one system doesn't always work in another.
    I don't have any high end equipment so I have spent a lot of time optimizing what I have for the environment.
    I have a set of Digital Phase AP2s in a large open room. They're rear ported and very sensitive to placement. A few inches in relation to the back wall make huge differences in clarity and weight. Foam wedges in the corners and some insulated wall panels also made huge differences here. Changing cables and other equipment has been more subtle.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • mantis
    mantis Posts: 17,557
    It all starts with speakers my friend. This is what you build around. The Room is super important and it can make or break your system. So room treatments placement and furniture all add tot he experience.
    The gear you purchase around the room and speaker needs.
    Dan
  • mlistens03
    mlistens03 Posts: 2,767
    An anvil in the speaker cabinets. :| lol
    I recently changed, uh, something and found what you are looking for. You don't know your missing it until you find it. I just gotta figure out what made the change, and keep it that way (I made a number of changes that day.)
    Good luck in your hunt!
    mlistens03 wrote: »
    Your well on your way to being a future audiophile young man. Never be afraid to experiment, shake things up, that's how we make discoveries that suit our ears.
    Everything matters....is the correct answer. Thing is, you have to isolate the piece, or cabling, or speakers, that isn't giving you those things and make changes. Can't squeeze blood out of a turnip as the saying goes.
    mhardy6647 Posts: 35,200
    single ended direct heated triodes and horns. The right horns, not the wrong horns.
    The right horns.
    The wrong horns.
    otherwise, yeah, it could get real complicated, as others' comments have implied.
    B)
  • mikeyb128
    mikeyb128 Posts: 2,885
    It’s taken me about 3 years to get heft and body. Hundreds of tube changes, and lots of equipment swaps. The Cary SLP 05 was the major player in this area. And going with a tube amp topped it off nicely. Then the tube swapping began, and I’ve finally found it. Hopefully the equipment marry-go-round is over for a while.
    2 channel:
    Theater:
  • Hermitism
    Hermitism Posts: 4,333
    Clipdat wrote: »
    Politeness.
    Clipdat Posts: 13,100
    Why are you so hung up on that?
  • joecoulson
    joecoulson Posts: 4,943
    SVS SB16 has some heft and weight to it
    my back says so
  • steveinaz
    steveinaz Posts: 19,546
    I'm no engineer, nor do I pretend to be---but I do have an opinion that over-built power supplies definitely help in getting good depth and weight. I also believe that the speakers account for about 75% of it. The voicing "profile" of a speaker is important. Speakers with a "pear like" response tend to have a weighty, satisfying sound profile.
    steveinaz wrote: »
    Everything matters... I have heard some pretty small speakers that ordinarily would sound pretty weak, start punching well above their weight with the right gear doing the pushing.
  • joecoulson
    I agree completely, back in the 90s and I bought my first NAD and I had been running a Sony reciever until that point. Not saying that NAD is super high end or anything, but it transformed the JBL’s I was running at the time. They sounded like different speakers.
  • maxward
    maxward Posts: 1,712
    I also agree. If you think that changing one little thing isn’t going to matter, try it and see. I’m thinking that “heft” implies to some people that there is an abundance of bass. So those folks might build their systems from the bottom up. Others will start with the midrange and work out from there.
  • dromunds
    dromunds Posts: 10,136
    Iron, my boys, really good iron!
    msg Posts: 10,458
    I have to put in a note for the right piece of front end gear and amp. That Musical Fidelity A5 was the single-most profound improvement for me in terms of weight and body.
    I think I know that sense you're after, Drew. It's always been difficult for me to articulate, but your choice of terms helps to describe it. One of those things where I know when I hear it, and can sense when it's not quiiite there. I think it's that thing that gives us that sense that there's more there, but not quite accessible, and keeps us searching. I think I've also heard it simply described as musical fidelity, accurate or not.
    Just for the sake of clarity, I didn't make this thread as a result of any perceived or real "shortcomings" or "performance anxiety" in my own bedroom.
    What? That's where my stereo is.
    It's simply a topic designed to spark thought provoking discussion, by sharing relevant experiences in this area by those who have been in the hobby for longer than I have.
  • afterburnt
    afterburnt Posts: 7,892
    Weight, body, and heft is what I look for in a shampoo and I am bald
  • joecoulson
    Stop looking at me swan
    pitdogg2 Posts: 27,236
    joecoulson wrote: »
    He has your number Joe
    afterburnt wrote: »
    or if your a pig farmer. :)
