Going To Be Without Tunes For Awhile
TheChemist
TheChemist Posts: 13
edited March 2019 in 2 Channel Audio
Few months ago had my internals rebuilt and did all the good things to my SDA-2B's. Sounding wonderful. Noticed when I increased or decreased the volume on my Krell KSL it crackled. Then, after about 15-20 minutes, there seemed to be some fading from the right (facing channel). Crap. Okay. I have a RMA from Krell. I am having to send this back and will also be sending my CAL Delta back East for tuning. Some CD's are scraping on something inside the transport and won't play. Ugh. I HATE being without tunes.
I am going to suffer. I'll send back Express Mail and hope to get them both within a couple of weeks. Until then....
  • halo
    halo Posts: 5,616
    Get some Klipsch "The Sixes" to use while your equipment is away. You can use your *gasp* phone's Bluetooth as a source. Better than nothing!
    https://amazon.com/Klipsch-Sixes-Powered-Monitor-Walnut/dp/B075JMBWVQ?th=1
  • stangman67
    stangman67 Posts: 2,328
    I have the klipsches in my temp setup and they sound pretty darn good!
  • verb
    verb Posts: 10,176
    Bummer dude! Sorry to hear. Never to late, but any backup gear?
  • polrbehr
    polrbehr Posts: 2,846
    I can sympathize with you as well, my 2Bs are currently wrapped in bubble wrap along with my entire 2 channel setup. Waiting for things to be put back after a most distressing mold remediation :(
