Focal JM Lab Mezzo Utopia modification
VR3
While the stock components are solid, can always improve!
Just starting the thread with the stock pictures, will update later
This will be an all out build
All parts after almost 20 years were right on spec...
.2 MH / .19 DCR (tweeter shunt)
3 MH / .29 DCR (First series Inductor in woofer network)
3 MH / 1 ohms (Second series inductor in woofer)
2 x .7 MH / .4 ohm (mid series)
1 x 2mh/.18 ohm (mid shunt)
Cap values –
1.46 (versus 1.5)
218 (versus 220)
8.16 (versus 8.2)
3.9 (versus 3.9)
49.38 (versus 50)
49.76 (versus 50)
15 (versus 15)
Resistor values –
3.63 (versus 3.6)
1.26 (versus 1.2)
.61 (versus .6)
4.8 (versus 4.7)
6.8 (versus 6.8)
6.79 (versus 6.8)
6.79 (versus 6.8)
1.24 (versus 1.2)
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The stock crossovers were very well built it appears... where can you possibly go from there, especially with them still being within specs.?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
They are well built, but they are also low end parts (respectively)…
These parts align with Solen as far as quality... (they were actually made by solen)
So my first objective will be Clarity Cap CMR throughout, even shunt parts, except the 220uf which will be Clarity ESA)
Sand cast resistors are garbage, so path audio throughout
Inductors are good, but they are bobbin wound, so I will go with perfect lay and replace all of the iron core inductors with air core/film as possible to match spec.
Resistors and caps have come a long, long way in 20 years!
Im not willing to push the budget that far and I know the performance CMR can provide. I did consider Duelund in some parts, but again, significant price increase.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Dueland caps?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Duelund makes caps, but they are extremely pricey, even the RS series which is "entry"- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yea they make Clarity CMR look like entry level in cost.Post edited by pitdogg2 on -
True that... I would have to build a second set of speakers just to put the parts in!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The iron core bass inductor as an air core weighs a whopping 7 pounds of copper. Love it.
Inductors ordered!
Only parts I am missing are the Clarity CMR 25ufs to make the 50uf
What is that 22000 axon ? Is that the 220uf cap? That looks yuuuuuuge
Yes 220uf, it's a big boy- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yeah, I'm not going cmr there because I would have to use 10, 22uf caps, which would be 2k in caps, not gonna happen.
I broke my rule on this cap because it's in the shunt position. I am using a 180uf and a 40uf Esa 250v because I got them on close out...
Wow!
An interesting comparison is to see what JM Lab did the next generation (the Alto). They used similar parts but you can see they removed all iron core inductors and they upped the resistor quality...
The gauge of the wires is significantly different as well. I think the cords to my stove and clothes dryer are smaller than those stock Utopia wires!
Sooo...while these speakers are out-of-commission, what are the backups???"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Just a question, with these larger caps does it take longer for these speakers to warm up when they've been sitting ??2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I haven't used the Utopias in months due to construction in the living room, they are boxed up. Wilson cubs in the office are keeping me entertained and the living room has the full in ceiling and in floor set up for movies.
Can't say I have noticed a warm up period... But they take 300 hours to break in... Just note, with the cmr, you are not actually seeing the capacitor. The cap is inside the thick red tube and the ends are epoxy filled. The cmr when you click it with your finger, it feels like a spring- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well, I traded you two pair of speakers (plus more) in obtaining my Mezzo Utopias from you, so I know you should have alternates
Inductors ordered!
Funny, I was going to ask you about the iron inductors and if you liked
the effect/sound. I'll show my ignorance and ask if they are actually needed
in speaker Xovers?Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
Iron cores meet a design goal... Cost and space.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Big ol 25uf caps have been ordered! 10 to 12 week wait... should work out perfect!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Had some spare time and my wandering mind has been contemplating the internal wiring scenario...
Removed all of the internal wiring, except for the bass driver (can be done later)
Replaced the tweeter diaphragm with a new one I ordered from Focal a while back. Supposed to be spec for spec the same but I figured since the original has a foam surround, it cant hurt! (no ferrofluid thankfully)
The best part about this was the fact the WBT posts have never been soldered, which will make it much easier to change the main incoming wiring...
The lead plate in the bass enclosure has come loose, I am thinking about simply removing this and putting dynamat in its place....
I sent email to focal about the enclosure. The midrange and tweeter cabinet are NOT sealed off in the wiring channels. This would in theory increase the enclosure size that the midrange sees. Given that the tweeter cabinet is purely a place holder for the tweeter and the connectors, built of 1/2" MDF and NOT properly sealed, this is a curious choice (and or error?). Will see what they say!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
So Im getting kind of jacked up about this... haha
Planning to use DH Labs Q10 from the binding post to the networks and DH Labs T14 to the drivers and for any lead extensions.
Going to remove any lead plates and properly dispose, replace foam with GR Research No Rez, which would effectively dampen the enclosure and negate back wave.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This has me curious too. If I understand you correctly, it’s similar to the leakage I was getting between internal compartments on the Elacs?
Cannot be part of the design as I would think one would affect the other. Should have been sealed at the wire hole -
Right, it looks like a complete oversite in the manufacturing process. *unless other pairs are sealed and mine are not*
And if you read the stereophile review, they noted an odd resonance in the midrange... of which I would absolutely contribute to this...
Will post Focals response when/if I receive it. They have been very forthcoming with info on the Mezzo so far though
OK now you have me jacked up. I want to rewire my 2.3tl's with their OCC 14a. Silver plated copper.Planning to use DH Labs Q10 from the binding post to the networks and DH Labs T14 to the drivers and for any lead extensions.
Can't wait to hear your thoughts on it.
Andrew Jones admitted to me that the first run Adante’s had the known issue of the mid/tweeter plate that the wires went through had a poor seal on it.
I used the t14 on my super towers and was very pleased. I would check out the t14 versus the 14 awg hook up wire, not a big price difference.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
