Looking for a new preamp
audioluvr
So you rotten enabling basteges are making me think I need to look into upgrading my old B&K Reference 50 Pre/Pro with a dedicated 2 ch. pre. Not sure if I want to go solid state or tube. What I do want is balanced outputs (and preferably inputs) and a remote. Also not over 10 years old as I don't want something that needs rebuilt. Hoping what I find will be my end game pre as I'm not looking for unobtainium. Let's say budget is in the $800 range.
Thoughts on brands/models?
A 10 year old end game pre for $800???? I've never seen or heard of such a thing but I wish you good luck.
With St. Patty's day approaching perhaps finding a bouquet of 4 leaf clovers first might help
The end game part killed me! 😂"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
There is a Parasound P5 for sale in the FM for 7 Benjamins.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Yep....perfect.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
In that price range, your not going to get everything you want. The P-5 for sale in the FM is about the best your going to do to match what you want. I wouldn't call it an end game piece though.
If your looking for just better sound than what the B&k offers, on the cheap, there's a MF 3cr pre for 600 on US Audiomart.
BTW, what speakers are you running ? I ask because of your request for balanced connections. Usually the higher sensitive speakers require balanced connections because the noise floor in your system is more easily heard.
lsi 9's -
Although the Parasound is a great deal, I am not sure it is much of an improvement in analog sound quality over the Reference 50. Seems like a lateral move with more up to date features including some that may not be needed. I had a Reference 50 and it was pretty good for two channel itself. It was an expensive and well designed piece of gear when it first came out.
I would recommend a bare bones tube preamp for something truly different. Trouble with that is balanced connections usually come with a bigger price tag and getting a good set of tubes can cost a significant amount too. -
Not listed anywhere, but I have a new/'never used' Parasound Halo JC-2 BP in black. Long story why I never used it. Fantastic solid state 2ch pre. But I'd be looking to get in the ~2500 range. PM me if interested.2.3TL's - Living Room
CRS+'s (4.1 TL's) - Office
SDA1C's - Famdamly Rm
SDA1C's - Master Bedroom -
^^long way from $800.00. But this would be end game for someone.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
PS Audio Stellar Gain Cell DAC/Preamp $1,100 if you can stretch the budget.
Thanks guys. Sounds like I just need to save up some more coin.Gustard X26 Pro DAC
At about the $1000 range you can go tubes. I did on the VTL 2.5 and also the EAR 834L. To me, the improvement was stunning.
Although not balanced connections.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I have a Cary CPA-1 in your price range that fits all of your criteria with the exception of "end game". That's a tough one to get at the price point you suggested. It does not have your preferred balanced inputs but it does have balanced outputs.
Someone else has dibs on it but if it falls through, it can be yours if you want it. FWIW.
Save your coin for a while and look for a Pass Labs X2.5...... Endgame for 1800 or so...So you rotten enabling basteges are making me think I need to look into upgrading my old B&K Reference 50 Pre/Pro with a dedicated 2 ch. pre. Not sure if I want to go solid state or tube. What I do want is balanced outputs (and preferably inputs) and a remote. Also not over 10 years old as I don't want something that needs rebuilt. Hoping what I find will be my end game pre as I'm not looking for unobtainium. Let's say budget is in the $800 range.
https://www.usaudiomart.com/details/649504579-pass-labs-x25/
According to his ad, he seems eager to deal on it.. I would offer 1250 on it and see how eager he is. Pass Labs service is exceptional, so I would have it sent there first before coming to you and have them give it a look before it comes to you. When they ship it to you, you will think you bought a brand new one.
http://www.enjoythemusic.com/superioraudio/equipment/0905/passlabsalephx25.htmPost edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Don't know about "end game", but I recently purchased a Schiit Freya that I'm happy with. Balanced ins/outs, tube, JFET or passive.
https://www.schiit.com/products/freya -
Eastern Electric Minimax preamp, if you can find one with the Tom Tutay mods, would be a great choice in that price range. Many people think you'd have to spend upwards of $3-4K to do better.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
My end game expectations are probably different than some of yours...
Good ideas so far! Thanks everyone!Gustard X26 Pro DAC
Aric Audio Unlimited tube pre? Pretty much bare bones and only RCA but custom hand made in the US. He lists the model with a phono pre for more on his website but has been listing a linestage one for $800 on Ebay (Not currently though).
https://www.ebay.com/itm/Aric-Audio-Unlimited-Stereo-Tube-Line-Preamp-phono-stage-not-INCLUDED-/153363421375?_trksid=p2047675.m43663.l10137&nordt=true&rt=nc&orig_cvip=true
So looks like I'm leaning towards the Cary line of pre's.I have a Cary CPA-1 in your price range that fits all of your criteria with the exception of "end game". That's a tough one to get at the price point you suggested. It does not have your preferred balanced inputs but it does have balanced outputs.
Tom, Thanks for the offer! It would be a good step up for me I believe. Hifiengine says it does have both XLR inputs and outputs. You sure?
I was also looking at the Cary SL-100's if I chose to stay with solid state. Not 100% sure I want to go SS or tube yet. Just seems tubes require a lot of tweaking to get the sound you like and I'm not a big tinkerer. I just like to sit down with a drink and enjoy the music.
Ultimately I want to replace my B&K pre with something I can enjoy for the next 15-20 years. I have reached out to @acmf74 who has a Cary SLP-03 for sale.Gustard X26 Pro DAC
Tweeking with tubes is easy, as opposed to having to buy/sell SS gear you don't like the sound of. I see that as a benefit, not a fault.HT SYSTEM-
lsi 9's -
dragon1952 wrote: »Eastern Electric Minimax preamp, if you can find one with the Tom Tutay mods, would be a great choice in that price range. Many people think you'd have to spend upwards of $3-4K to do better.[/quote}
I can second the Eastern Electric MiniMax suggestion. I bought one a few weeks ago from a PF member and absolutely love it (the one I have does not have the mods which dragon1952 mentioned). It is a great pre and a great value at its price point and would be within your budget. Plus it is a great way for a tube newbie (as I still am) to get into tubes as the MiniMax only has 3 (very accessible) tubes. You have to be patient looking for one though as they do not routinely come up for sale. -
Good point.
The EEM's don't have XLR or remote. Since I've already invested heavily (to me) in this for what I have I wanted to stick with that. Also no remote no go. I'm lazy...
TOOBS dude!
Tubes add soul!
Schiit Freya tubed, it’s new great service and <$700. Seems to fit the bill.
rayRay Campbell
Bucyrus, Ohio
Carver Research Lightstar.....words fail me -
Yep... fills your bill and easily resold if you hate it. I've got the Saga and it's very impressive.Aaron
Enabler Extraordinaire -
Schitt is getting real!"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Where do you sell Schitt ?My New Year's resolution is 3840 × 2160
In the long run, would I be better off with Schitt or Cary?Gustard X26 Pro DAC
