Bluesound Node 2i
13»
  • Mikey081057
    Mikey081057 Posts: 7,127
    You can also play it to a Bluetooth device TB.... And i think roon supports your Sonos devices as well so you still use them. I don't think you can join the dis-similar bluesound and Sonos devices but you would be able to use roon to control everything.
    Garage | Polk Monitor 5B's
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2019
    Yes to all of your questions. I have a good router/cable modem so I have no issues even getting a great signal out in the shop. Router is basically in the center of the house, in a bedroom. The current play que is displayed on the right of the screen by default.
    FWIW, I use an Ipad mini 4 to run BluOS. My cable internet account w/Cox is the 2nd from the Top tier of internet bandwidth; real world down loads wirelessly are typically 30-40Gb, via Ethernet right at 100Gb.
    Your a good salesman Steve. :)
    Thanks for answering all my questions, gonna have to order me one.
  • steveinaz
    edited March 2019
    Have you used Tidal Tony?
    It's difficult for me to articulate sound quality because I also have a new preamp/dac in the mix---whatever the case may be, they sound great as a combo.
  • deronb1
    deronb1 Posts: 5,021
    steveinaz wrote: »
    BluOS seems really intuitive. I haven't had any issues.
    Me either. I leave the Node2 on all the time so I dont have to keep reloading the files
  • Mikey081057
    So I have listened but not compared the 2.
  • steveinaz
    edited March 2019
    IMPORTANT NOTE: Something I forgot to mention, the Node 2i is the first network player I have owned that actually does gapless play correctly, without any intervention. I tested it with 3 different albums (Rush, Pink Floyd, Boston)....seamless. Other players have introduce a slight "hitch" or blank spot before transitioning to the next song, including my Oppo, which you also had to select "gapless play" before playing the album, instead of it just working without intervention. Bravo Bluesound!
  • Mikey081057
    Bluesound fixed Strahan's Gap too
  • Mikey081057
    And another case for roon is that roon radio now rocks.... I've been on roon now for like 15 months and they constantly fix and enhance it... Who ever it is that's in charge over there outta consult for Polk on soundbars
  • steveinaz
    ...and they gave him Bluetoof.
    steveinaz wrote: »
    LOL....and that's you being sober, must be a blast to hang with after a few drinks in ya. :)
  • steveinaz
    Some stats on album art and BluOS; cover.jpg or folder.jpg (*.png also acceptable), resolution doesn't matter, as everything is sized to 600x600, but there is a 600kb max file size limit.
  • deronb1
    Im loving the Node2 so far. Cant imagine how the 2i could meets my needs any better, being hard wired and all.
  • steveinaz
    There's not much difference. I love this thing.
    Steve,
    I know you used to run your files threw the OPPO, have you compared the files run by way of the BS in comparison ? Better/worse/same ? Sound wise obviously.
  • steveinaz
    edited March 2019
    I want to say the sound seems a bit more refined via the HDD-->Node 2i. The interface is CERTAINLY far better, far faster, as is gapless playback. The Node 2i just WORKS exactly as you would expect it to. No hitches, no strange behavior, fast indexing, etc. With the Oppo, music playback feels like an after-thought.
    Imagine building a workbench with hand tools = Oppo
    Imagine building a workbench with power tools = Node 2i
    Pretty much sums it up.
    LOL...Thanks Steve.
  • steveinaz
    Tony, do you have an Ipad?
    No Steve, not an Apple guy, and don't intend on being one down the road. Any tablet should work with the B.S. anyway.
  • Mikey081057
    I am android and windows and the BS app and utilities all were supported... heck I even think the app works on Kindle....
  • steveinaz
    edited March 2019
    I have an Ipad mini 4, but use a Windows laptop. Basically bought the Ipad to use with these new network players. Back when I had my SQB Touch, I bought the fancy-pants remote with screen. I sat too far to see the SQB screen.
  • hochpt21
    hochpt21 Posts: 5,423
    Pulling up an OLD thread, but didn't feel the need to start a new one.
    Stupid question below possibly, but I can't quite figure it our with certainty.
    Right now I have a little $30 bluetooth receiver I stream Spotify from my iPhone to my main system for dinner/background music. Problem is, whenever I use my phone for anything else it interrupts that. The Node 2i streams Spotify on it's own, correct? So I can use any other app on my phone without interrupting the music?
    And if so...do I control Spotify through the Bluesound app? Or do I send the music through my Spotify app to the Node?
    Thanks in advance.
    Paul
  • Joey_V
    Joey_V Posts: 8,603
    I think you control Spotify within the blueOS
  • hochpt21
    Thanks Joey
  • rooftop59
    rooftop59 Posts: 8,120
    hochpt21 wrote: »
    Thanks Joey
    You can also use Spotify connect (and Tidal as well) which means you pick the songs from right within your Spotify or tidal app on your phone and your phone just tells the node what to play. It’s not Bluetooth. It’s very slick and convenient.
    Game Room 5.1.4:
    Bedroom 2.1
  • hochpt21
    rooftop59 wrote: »
    hochpt21 wrote: »
    Thanks Joey
    Perfect, this is exactly what I was looking for.
