When I switch channels on TV the surround sound starts briefly each time I switch but then stops.
FAMS99
The surround sound comes in when switching between channels but only briefly and during commercials but not during programs.
Best Answers
You'll need to provide a helluva lot more information such as what brands and models of gear are you using.Political Correctness'.........defined
President of Club Polk -
Which receiver are you using? Hopper?
The dish receiver should be set to output Dolby digital . -
Yes, it is set to Dolby Digital.
Volume Leveling is off and Dynamic Range is set to Wide.
Check TV settings
Answers
It is a MagniFi Max Sr 5.1
Are you sure the programs are being broadcast in surround sound?Political Correctness'.........defined
Would it start the surround sound briefly if it wasn't?
Are programs on the major networks like Good Morning America broadcast in surround sound? We had a wired surround sound system that we could choose to use for anything on TV. Why are the commercials broadcast and not the network programs?
Thanks for your help.
Did someone switch how the sound is being output from the TV?
No one has done anything except the Dish installer.
Did the issue start after the Dish service was installed?Political Correctness'.........defined
Immediately after.n
Yes the hopper. How would I check that setting?
Go into your settings find audio
Is that on the Dish remote?
