Is anyone running an Aries Mini with an internal HD installed?
If so, how do you add files to the HD. I used to be able to copy and paste files to it when my Aries showed as a computer on my network. This ability disappeared from my PC's one by one.
  • voltz
    voltz Posts: 5,384
    edited February 2019
    Hey B
    Just put your song onto a flash drive and plug it into the back of the mini to the left :)
    then go into setting and look for a way to add/import song to the drive via USB... I will have to find the correct way to see where to click on Import from files (USB) for you later tonight...
  • voltz
    voltz Posts: 5,384
    ok just plug your USB flash drive in back of Mini...then fire it up...
    in the lightning app goto settings: then click on music library
    then where it says currently available click on what ever is there...mine says Lightning Servr (living room)
    then click on additional operations = then in the second box down...should say "Library Path Info" and HDD connected below that..
    Click on HDD and the box will open more..about six lines down it should say "Import Music from USB Drive" click on that and it should start down-loading your music from the Flash Drive!
  • afterburnt
    afterburnt Posts: 7,892
    @voltz Darryl, I got one PC working right again but in case it quits again, will the thumb drive method let you select which folder the new Music goes to? I have my music in a bunch of different sub folders.
  • WagnerRC
    WagnerRC Posts: 2,200
    I have 2 mini’s with 2differnt brand hd’s Installed and neither would be recognized after install. I gave up . I have a cxn v2 coming next week to see if it can replace the mini in quality of sound .
    msg Posts: 10,452
    Bob, presume you tried to initialize the disks through the app?
  • erniejade
    erniejade Posts: 6,321
    WagnerRC wrote: »
    I have been looking for a mini but interested in hearing your thoughts on the cnx vs the mini. Please keep me in the loop on your findings.
  • afterburnt
    For the record I will be doing an apples to apples comparison of the CXN and the Mini. When I do I will post my findings.
  • WagnerRC
    Yes I tried the app and I am using ss drives. I will find the part numbers . It's 2 different brand drives. Thanks
    The mini is fantastic for sound quality . I have no complaints there.
  • afterburnt
    @WagnerRC just wondering did you load music before you installed it?
    Clipdat Posts: 13,089
    afterburnt wrote: »
    Granny Smiths or Fujis?
  • WagnerRC
    Samsung Seagate Spinpoint M9T 2TB
    Samsung Seagate Momentus SpinPoint 2TB
    These are the drives
  • WagnerRC
    afterburnt wrote: »
    No i did not, blank
    msg Posts: 10,452
    Does the Initialize Internal Storage option even appear in the app? or does it not get that far?
    https://support.auralic.com/hc/en-us/articles/206621237-How-to-Start-Using-Internal-Storage-
    From the article above:
  • WagnerRC
    It doesn't get that far.
    msg Posts: 10,452
    WagnerRC wrote: »
    Do you have the option to set the "Lightning Server Work Mode" to Hard Disk?
    afterburnt wrote: »
    Format?
    I think that's what the Initialize Internal Storage command does, Bruce, but you may not even see that if it won't detect the disk.
  • WagnerRC
    It just wont detect the disk. No "Lightning Server Work Mode" to Hard Disk?
    msg Posts: 10,452
    So weird. Not like Seagate's some bobo brand or anything.
    Looks like a pretty straight forward process.
    Got the latest firmware too?
  • afterburnt
    edited March 2019
    All is lost...Again! PC went back to normal (SNAFU) and I can't find a way to "add" music to the internal HD. And my DSL is down again to boot (to the head).
  • afterburnt
    @voltz Darryl I didn't get "Import Music from USB Drive" as an option.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Maybe the Aries needs a tune up?
    Garage | Polk Monitor 5B's
    msg Posts: 10,452
    I had the wagon version of that when I was a kid. No AC and rear windows that didn't roll down.
    It caught fire one day at the foot of a pretty girl's driveway while I was returning her camera for a friend. Her mom was down nearby moving the sprinkler and saw the white cloud coming from the gaps and said, "Oh, is your car running a little hot?" I said, "Yeah, it does that sometimes." She said, "Well, you're welcome to some water," as I popped the hood. It was not steam, it was smoke. And flames. She ran off screaming. I ran up after and grabbed a bit bucket of water and ran back down the driveway wrestling that 5gal bucket, and doused the engine.
    Her dad, a well to do gearhead, fixed it up enough for me to get it home.
    I thought he was being nice. Thinking back now, remembering the frenzy and determination with which he worked, I realize now that it was simply more likely that he didn't want it sitting there any longer than necessary.
  • afterburnt
    Nope mine is reengined with a Pratt & Whitney J75
  • WagnerRC
    I received 2 of these today. Very nice product. Thanks again for the tip.
    https://eshop.macsales.com/item/OWC/MOTGS3U3
    msg Posts: 10,452
    Nice, Bob, yeah, those little enclosures are pretty nifty. Glad you like 'em.
    Just in case it's not clear to anyone else, they work on both Windows & Mac machines.
  • afterburnt
    msg wrote: »
    they look clear, what are they?
  • codycatalist
    codycatalist Posts: 2,662
    afterburnt wrote: »
    msg wrote: »
    An enclosure for an internal HD that will repurpose it to be used as an external device. I'm looking at the same one for my Seagate HD
    msg Posts: 10,452
    That is, indeed, what they are. Nice little enclosure for bus-powered USB disks with a power switch and heatsink. Comes with a handy little bag and short USB 3 cable.
    Works with 2.5" spinning and SSD disks, with the real benefit in the use of SSD with USB 3.0. I mentioned it to Bob as a means of repurposing the SSDs that weren't working in his Mini.
    Bit of a side-jack here, Bruce, sorry; it won't do anything to help with your Mini/Network issue. I can try to help you with that when your internet's stable.
    Side note here - I heard back on an inquiry to Auralic. They recommend a few brands, the tech specifically recommending the Samsung EVO series, but he said that anything requiring greater than 5v/1A spec would not work correctly in the Mini.
  • afterburnt
    No side jacked, my threads are jacked from the inception
    msg Posts: 10,452
    Bruce, I just messed around with a few things to give you some stuff to check.
    Here's a process I think may help make sure you're set to be able to see everything. This is for Windows 10.
    • Right-click Windows Start Button, click Network Connections
    • Under Network Status Area, verify that you're set to Private Network. If not, then
      • click Change connection properties
      • Set Network Profile to Private
    • Go Back.
    • Click Sharing Options
    • Set Turn on Network Discovery
    • Set Turn on File & Printer Sharing
    • Save Changes
    • Repeat on all machines
    - click Change connection properties
    - Set Network Profile to Private
    Go Back
    Save Changes
