Oral surgery
dragon1952
Went in for my semi-annual dental checkup/cleaning and they found a cyst on my gums...about the size of a dime and I hadn't even noticed it. Evidently it's a tumor (benign) but they can actually grow to the point where they get behind the ocular nerve or even all the way to the brain so that they can't remove them. Anyway, I'm scheduled for this coming Tuesday and they're going to have to remove 3, maybe 4 teeth and "some bone". Depending on how much bone they remove you can end up with a cavity between your sinuses and teeth that can cause chronic sinus issues. I have never had issues with my teeth :^ / Not looking forward to this at all. Wish me luck. At least I get oxycodone, which I've found goes great with beer and weed :^ )
That sounds awful. Good luck. Hope it works out well.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Best of luck and God speed to you for recovery.
Good luck on surgery. Enjoy the Oxy's n weed
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Ha ha...thanks guys.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Good lucklsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5 -
Best of luck! Get well soon!!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Wishing you the best.
Get well soon.
Good luck with all that. Stay strong and take care of yourself. Keep us posted on your recovery. I hope it is speedy and with out drama .
Love yours. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?” -
Good thing you went regularly and the dentist identified the growth early. I had a coworker years ago who did not catch a similar thing early and the consequences were really bad for him even though it was not cancerous.
Sinus perforations usually fix themselves, and there is bone grafting they can do as well if they need to when a tooth is removed. I had both of my top back molars removed in the last year. My tooth roots are terrificly long and a root canal failed on one leaving a chronic infection under a crown. There was a minor sinus perforation on one side because tooth roots can be close to the sinus cavity, but it healed itself and I had bone grafting material placed for implants and to speed the healing processes. Much better after getting that stuff done, although it does take time and money.
Good luck and heal well! -
Good luck to ya! I too underwent oral surgery a month ago. Having an implant put in. Long story, but an old injury finally took it's toll on my tooth. So now I have to wear a retainer until healing process is finished. Ugh.
Hard for me to proclaim, but this guy and I now have something in common!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Good luck Dragon, the good news is that the mouth heals very quickly.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Yes, good luck! I start to sweat and the tech wonders why my blood pressure is so high when I go in for a small filling. Buy you a beer when you’re feeling up to one? I’m in S. Salem.
Best of luck with that. God speed with recovery...AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I hope your surgery goes smoothly and you heal quickly.
Good luck mister
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Sounds scary, glad they caught it early and best of luck on the procedure.
Thank you very much everyone. It means a lot :'(2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Ha ha...thanks! I remember that episode!2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Good luck and keep your spirits up.
Speedy recovery for sure. -
Good luck dragon! I HATE dental work. But it’s better than the alternative! Best wishes for a seep day recovery!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Hey, good luck and wishing you a very successful outcome.McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Good luck, hopefully it won't be as bad as they told you.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
Yeah that's always a possibility....thanks!2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Best of luck for Tuesday. Let us know how everything goes.
Dang dude this sounds painful. To a successful, full recovery.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Good luck, buddy.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks guys....I appreciate the thoughts.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
https://www.youtube.com/watch?v=iMLKbXuv-xA
