Hafler 500 Upgrade
  • Sweet, some serious capacitance going on there. That thing is going to be a beast once you are done.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; Cables ZU Mission IC's, SC and power cords, all into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All speakers have had crossover rebuilds, resulting in a small fortune invested in Sonicaps, and tweeter upgrades.
    Political memes posted as fact and accepted as fact, are sign language of the ignorant, for the ignorant
    tonyb said " but even socialists can do a good thing here and there
    Social media makes dumb people dumber and smart people dumb then dumber.
  • machonemachone Posts: 1,134
    edited December 2018
    Got the board, rectifiers and components for the power supply upgrade.
    SRS 2.3TL (Fully Modded)...SDA-1A (Fully Modded with Dimensional Tweeter Delete)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • gp4jesusgp4jesus Posts: 1,250
    Thanks, I really want to get the XL600 freshened up. I love these big Haflers.
    a side benefit to doing PS upgrades* in the XL 280s & 600s is they come from Hafler w/separate rectifiers & cap banks for each channel making the aforementioned* easier.
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 976 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7 w/Rotels. Woofers - 980BX; M&T - 981
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: an Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    To the OP: did MC provide the wire to connect to the binding posts or did you reuse? In my XL280 I found subtle & not-so-subtle improvements using better/heavier wire for the above & PS caps to driver boards.
    I replaced the wire B-B+ from the ps to the driver boards but not the wire from the driver boards to the speaker posts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    I got 150 hours on the PS upgrade.
    It's really really good.
    Smooth as silk.....
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Just hit 300 hours.
    Really opened up with a powerful bottom end. Wrap-around 3d soundstage. I did not expect this upgrade to have such a positive impact on SQ. I am pleasantly surprised.
    Do these 2.3TL's have a limit !?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    I replaced all of the wire running from the power supply to the driver boards and from the driver boards to the binding posts with 12 awg. Also, I replaced the 35 year old thermal paste under the MOFETs. B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • ClipdatClipdat Posts: 7,240
    What type of thermal paste did you go with?
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Well, after rewiring the power supply to driver boards, driver boards to speaker posts and replacing the thermal paste under the MOSFETS the amps mojo fell off. I had an oops o-carp moment. :'(
    250 hours later the mojo is back in spades. It took that long for everything to settle and burn in! :)
    It is sounding great B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • audioluvraudioluvr Posts: 1,379
    machone wrote: »
    What wire did you go with?
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
    WireWorld Mini-Eclipse 7 speaker cables
    WireWorld Silver Eclipse IC's
    Cambridge Audio Azur 851N - DAC/Streamer
    B&K Reference 50 Pre/Pro
    B&K M200 Sonata Monoblocks
    BLE-Design 16mm Power Cables
    Denon DVD 2900
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    BluDenso - Bluetooth receiver/DAC
    What wire did you go with?[/quote]
    I got it through Musical Concepts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
Howdy, Stranger!
