DVDShrink question
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited December 2004 in Music & Movies
I've decided to back up some of my DVDs and actually put the originals in safekeeping and watch the backups on a regular basis...so I've got everything need and understand everything...just one question...
With DVDShrink, how much can you compress the video before noticing a difference? I've got a fairly decent TV at 57", but nothing too huge. Do you think I can get away with 85% or so, or is that too much compression? Anyone who's used this program, I'd appreciate any input...
  • bknauss
    bknauss Posts: 1,441
    I've watched DVDs on my decent Toshiba flat screen, component cables from a cheap Toshiba DVD player, and I haven't noticed a difference at all when I use the special video compressor thing (not just straight compression... there's an option where the program will play around with the compression).
    Obviously this isn't an HDTV using a prog scan player... so make as many assumptions from that as you want.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • PolkThug
    PolkThug Posts: 7,532
    Strip out all the extra junk so you don't have to compress so much. For instance, you only need one audio track, get rid of the rest. Also get rid of previews, warnings, and extras. If you ever have a desire to see the extras, just get the original disks out.
    Regards,
    PolkThug
  • Shizelbs
    Shizelbs Posts: 7,433
    The only time I have noticed compression effecting the video was with Scarface at about 60% uncompressed. It was quite noticeable at that point. I really don't look for video quality all that often.
  • AsSiMiLaTeD
    Regards,
    PolkThug
    I've done that, and I am still at about 83% with I Robot...I can get a little bit more if I keep the DD track instead of the DTS, but yeah, I've stripped everything out...
  • Shizelbs
    Often times, thats just how it goes.
  • bknauss
    I just backed up Spartacus this weekend, and even with just the movie and the 5.1, it had to be compressed down to about 62%. Stupid 3 hour and 10 minute movies! Damn you Kubrick!
    Brian Knauss
  • Sami
    Sami Posts: 4,634
    Keep the DTS and go with 83% compression. It was hard to notice any difference with 78% compression on Johnny English and you have seen the screen size I'm using.
  • AsSiMiLaTeD
    Yeah, that's what I ended up doing and I didn't see any difference either...I could up close, but who watches a movie from six inches?
    Okay, one last question - What's the easiest way to burn a DVD with a bunch of scenes from different movies?
  • Sami
    Sami Posts: 4,634
    I haven't tried but wouldn't DVDShrink do that as well? Have you played around with that
    menu?
  • PolkThug
    menu?
    DVDShrink will "rip" the scenes, then you need another program like Nero or Alcohol 120 to "burn" them.
  • AsSiMiLaTeD
    When I rip the scenes in DVD Shrink, it's going to give me three options...
    rip them directly to a DVD (using Nero to burn)
    rip them to an image file (.iso)
    rip them as DVD files (I think)
    so should I rip these as an image or directly as DVD files? I assume option 2 since I don't know if Nero will let you burn multiple images on one disk...
  • PolkThug
    I think you need to keep doing option 3 until you get them all done.
    Then you will drag and drop them all over to the left and use option 1.
  • Loud &amp; Clear
    Loud &amp; Clear Posts: 1,538
    Well, I usually don't start out watching from 6", but I invariably end up that way when watching one of my pornographic motion pictures. I can't seem to get any closer than that, though.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Shizelbs
    DVDshrink is great for that.
  • AsSiMiLaTeD
    Okay, I consider myself to be fairly intelligent, but I can't figure this out...
    Is there a way with DVD Shrink that I can rip just a chapter from a movie - without having to use the set start/end frame stuff...becuase that's going to be a **** when ripping multiple scenese from several movies, especially when I just want entire chapters most of the time...
  • PolkThug
    On the start/end, you can just pick chapter 18 from the start drop-down box, and pick chapter 19 from the end drop-down box.
  • AsSiMiLaTeD
    ah Jesus Christ...
    can't believe I missed that...
    thanks
