Stands for Lsi9's
daboyz
Looking for a nice pair that can handle the weight. Don't want anything high end. Suggestions or do you have a pair?
Thanks!
Thanks!
These worked well fro me in the past: https://www.amazon.com/dp/B004STEH08/ref=psdc_3236443011_t2_B004T7VCM0Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
How tall are you looking for? I would have to look but I think I have some you can have if I still have them.
22" to 24"
Sorry Dave. I must have gave them away with the speakers.
Damn you Andy! No worries. Mine are with my daughter at college thus the search..
These are a good choice. I have my Lsi9's on 26" Sanus Ultimates, but they are no longer available. My 706 center is on a Sanus SFC-22 which has been modified with the tubes from a 26" stand. It's filled with kitty litter & rock solid holding the big Polk center. -
Seconded. I’ve got my A6 center on a SFC-22. Drilled a bigger hole to more easily add sand to the tubes. Red Locktite on all the hardware. Rock solid. Improved the sound over the small table I was using before.Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
I did buy a pair of those off Amazon. Thanks Paul for the recommendation!
