Aperion Audio Super Tweeter
woodhead 2
in Speakers
299 for a pair. Anyone try these? Kind of wonder how they would sound sitting on top of my Monitor 70's.
Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
FWIW -- There was some of chatter about these and the topic in general fairly recently @ AK:
http://audiokarma.org/forums/index.php?threads/thoughts-on-super-tweeters.842925/
I haven't heard 'em -- what I'd recommend is to think about what "problem" you're trying to "solve" before investing too much lucre in the solution
Do you want extension of HF response, increased HF dispersion or a change in the character of the treble? Or all three?
Again FWIW -- I am a pretty dedicated "super" tweeter user due to the limitations of the treble horns in my big-boy loudspeakers. I need extension (but not into the ultrasonic!) and dispersion. The "supertweeters" I use aren't technically supertweeters, but they mate fairly well with the treble horns using a simple first order XO and an L-pad (variable) to normalize the output.
Not really trying to solve a problem, just looking to make improvements. I read your link, and didn't sound like it would make much difference. But, thanks for the reply.Panny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up] -
Oh it will make a difference. It looks like you can shape it to some degree with the
AAST. As Doc stated so well, will you be able tune it in to your liking?
I would save the money for speakers that have been designed for use with
a super tweeter. FWIW.Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
Your probably right. ThanksPanny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
well, I would say "save your money and experiment with something a little less dear (as in
less expensive)"
I wouldn't discourage anyone from playing around a bit. That's how we learn -- unless, of course, we manage to kill ourselves in the process. In that latter case, we do still learn, but it's fairly academic at that point.
