Parasound P/HP 850 preamp
cortico
Selling this preamp, it’s in great condition and sounds pretty nice, $180 plus shipping.
Description from Parasound:
A uniquely cost-effective preamplifier that doesn't compromise your music. A massive power supply for deeper, cleaner bass and better dynamics. The fact that it's direct coupled for the cleanest possible signal and has five inputs-including a clean RIAA phono stage for your turntable-makes this a value that's hard to beat.
FEATURES
Four high level inputs, one phono input
Direct coupled output
100% pure Class A circuitry
19,000 µF power supply
Premium Alps and Noble volume and balance controls
Silver plated OFC internal wiring
Smooth sounding Analog Devices operational amps
Defeatable tone controls
Accurate RIAA curve for phono stage
Tiffany-style gold plated RCA jacks
Removable IEC AC cord
SPECIFICATIONS
Frequency Response:
10 Hz - 100 kHz, +0/-2 dB, full output
Distortion:
< 0.009% THD, 1 kHz;
< 0.01% THD, 20 kHz;
< 0.01% IM
Maximum Output:
> 10 V before clipping
Input Impedance:
High Level 30 k ohms, +/- 5%;
Phono 47 k ohms, +/- 5%
Input Sensitivity:
High Level 150 mV;
Phono 2.5 mV
Max Input Level:
High Level 9.5 V;
Phono 160 mV
S/N Ratio:
High Level > 93 dB, A-weighted, full output;
High Level > 90 dB, A-weighted, full output -6 dB;
Phono > 65 dB, A-weighted, full output
Maximum Hum:
< 0.04 mV, full output
Crosstalk:
> 60 dB, >= 10 kHz, full output
Separation:
> 80 dB, <= 10 kHz, full output, tone controls off;
> 60 dB, <= 10 kHz, full output, tone controls on
Channel Balance:
<= 0.8 dB
<= 1.5 dB, -60 dB
Tone Control Range:
+/-10 dB, 100 Hz; +/-10 dB, 10 kHz
Dimensions:
w 17 1/4 " x h 3" x d 16", h 3 5/8" with feet
Net Weight:
13 lb.
FEATURES
SPECIFICATIONS
Frequency Response:
Distortion:
< 0.01% IM
Maximum Output:
Input Impedance:
Input Sensitivity:
High Level 150 mV;
Phono 2.5 mV
Max Input Level:
High Level 9.5 V;
Phono 160 mV
S/N Ratio:
Maximum Hum:
Crosstalk:
Separation:
Channel Balance:
<= 0.8 dB
<= 1.5 dB, -60 dB
Tone Control Range:
Dimensions:
Net Weight:
13 lb.
Great basic preamp that hits way above it's price.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Yes, it’s a well thought sweet sounding classic 2 channel amp. Very well built, has a couple hand full of the now mythical Black Gate capacitors. Selling because I just got is big brother the pld2000
This unit sold on eBay, thanks
