Hafler 500 Upgrade
  • Sweet, some serious capacitance going on there. That thing is going to be a beast once you are done.
    – Kevin Alfred Strom
  • machone
    machone Posts: 1,551
    edited December 2018
    Got the board, rectifiers and components for the power supply upgrade.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I installed the ps upgrade last night.
    Removed caps, rectifier and installed standoffs.
    Board populated and tracks filled with solder.
    PS installed.
    Fired it up with a variac and checked the ps output voltage, all good. Installed the driver board fuses and checked the bias, all good less than 5mv.
    Put back in the rack and fired it up.
    I am impressed. No noise, very musical and rock solid but very delicate at the same time. These modern capacitors are quite amazing. Definitely more tactile bass while cymbals slowly decay and recording room ambiance is enhanced. I could not be happier.
    I had goosebumps with body rushes..... :):)
    I am out of town for the weekend and can't wait to get back and listen some more.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • gp4jesus
    gp4jesus Posts: 2,016
    Thanks, I really want to get the XL600 freshened up. I love these big Haflers.
    a side benefit to doing PS upgrades* in the XL 280s & 600s is they come from Hafler w/separate rectifiers & cap banks for each channel making the aforementioned* easier.
    *all connected w/Premiere ICs
  • gp4jesus
    To the OP: did MC provide the wire to connect to the binding posts or did you reuse? In my XL280 I found subtle & not-so-subtle improvements using better/heavier wire for the above & PS caps to driver boards.
  • machone
    I replaced the wire B-B+ from the ps to the driver boards but not the wire from the driver boards to the speaker posts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I got 150 hours on the PS upgrade.
    It's really really good.
    Smooth as silk.....
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Just hit 300 hours.
    Really opened up with a powerful bottom end. Wrap-around 3d soundstage. I did not expect this upgrade to have such a positive impact on SQ. I am pleasantly surprised.
    Do these 2.3TL's have a limit !?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I replaced all of the wire running from the power supply to the driver boards and from the driver boards to the binding posts with 12 awg. Also, I replaced the 35 year old thermal paste under the MOFETs. B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Clipdat Posts: 13,078
    What type of thermal paste did you go with?
  • machone
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Well, after rewiring the power supply to driver boards, driver boards to speaker posts and replacing the thermal paste under the MOSFETS the amps mojo fell off. I had an oops o-carp moment. :'(
    250 hours later the mojo is back in spades. It took that long for everything to settle and burn in! :)
    It is sounding great B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    audioluvr Posts: 5,865
    machone wrote: »
    What wire did you go with?
  • machone
    What wire did you go with?[/quote]
    I got it through Musical Concepts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Hello, any further updates or impressions? Anything you would differently? btw : where did you purchase the oslo power switch, is it lighted?
    Thanks!!
  • machone
    I've had a lot of fun and learned a lot upgrading the Hafler. Very little original except the chassis and mosfets.
    I would not change a thing but I would like to try Musical Concepts new PA7 frontend someday.
    Got the HD lighted switch from Musical Concepts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Just upgraded my speakers to Acoustat 1+1s , My Musical Design D75 dies, and I'm digging out my old DH500. Had purchased many years ago PA-3b boards and dual mono transformers. Going to use the PA-3B boards , transformers, and update to the most recent MC dual mono board and Mundorf 15,000 Caps. Anxious for the parts to arrive to get started. Ordered Mundorf 1500 caps for the on board PS for the PA-3B, will have the Mundorf and a set of Blackgates for the other caps on board. Will run these for a while until I can upgrade again to PA-7s.
  • machone
    The power supply is a definite upgrade. I think you will be pleased. I also added an IEC socket and upgraded the power cord.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Have mogami wire to construct power cable, along with Connex Power/IEC Plugs Rhodium-Plated Copper , along with IEC rhodium /copper receptacle.
  • levier
    levier Posts: 2
    Machone... I have recently purchased a working DH500, planning the exact upgrades you have done. How is documentation/ instructions from John? I have experience rebuilding, upgrading Dynaco ST400, with success, pretty sure I can follow good set of instruction.
    Did you have any issues getting responses to questions? Not familiar with filling solder tracks, is this a hot plate or oven procedure?
    Thx...
  • machone
    Excellent instructions and support. John knows Hafler. I used a soldering iron to heat and fill the tracks with solder.
    Have fun!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
