Acoustic Panel Build
Thanks MikeMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I pushed the speakers back another 1/4" closer to the wall. Not impressed. Undid the move.
Then I moved them 1/2" further apart. Best so far.
Also, I am using a string across the baffles to make sure they are parallel.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I pulled the speakers out from the wall another 1/4". Better sound stage and cleaner, stronger bass.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
txcoastal1 wrote: »Here are some I built for LSAF. Stands are made with black pipe and base filled with lead shot.
That looks quite similar to what we made for one room.
Was that Roxul from Home Depot by chance?
The Dyn's being rear ported and the walls at LSAF are concrete so I needed something for the bass....I used this
https://www.acoustimac.com/ecoinsul4222-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
