AVR for RTiA5 and 4kTV: Denon X2400h vs Pioneer VSX-LX302 vs Onkyo TX-NR686
French_guy
in Electronics
Looking for a receiver under $350 (A4L) for my RTiA5 and 75" LG 4K TV
I also thought about the Marantz NR 1608, but not sure it will be "punchy" enough.....!!!
Which one would be the best choice?
Application is 95% HT
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
No surround...yet
Of the three you listed, I would go with the Denon.
Denon will be fine. Avoid the others...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Yeah, I thought Denon would be the best pick...
How does the new S940H compoare with the x2400h by the way?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
French_guy wrote: »Yeah, I thought Denon would be the best pick...
X series is better made than S, with an additional year warranty and better calibration software. If you can afford the S940, buy the X3400H. -
Both S940H and X2400H are under $350 on A4L, and S940H comes with Multi EQ when X2400H comes with Multi EQ XT
X3400H has Multi EQ XT32, but price is $500
So X2400H seems to be the best compromise after all.....RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
XT32 is much better if you can swing it...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
French_guy wrote: »Both S940H and X2400H are under $350 on A4L, and S940H comes with Multi EQ when X2400H comes with Multi EQ XT
The $500 buys you a few things. Better calibration program as well as a better power supply, things you don’t really see but are important none the less. This is true for all manufacturers. As the units move up the food chain, build quality and internal parts become better, even if you see similar features. -
Well, i can still wait a little, hoping A4L makes a discount on the 3400 for the New Year.....................Who knows ???RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
This is also the time of year with a lot of returns, so may want to check open box at various retailers.
Good point, I can go take a look at some Best Buy around me....RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
Yeah I would go for the 3400 if you can, It has preouts if you want to add an amp laterWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
