AVR for RTiA5 and 4kTV: Denon X2400h vs Pioneer VSX-LX302 vs Onkyo TX-NR686
Looking for a receiver under $350 (A4L) for my RTiA5 and 75" LG 4K TV
I also thought about the Marantz NR 1608, but not sure it will be "punchy" enough.....!!!
Which one would be the best choice?
Application is 95% HT
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
  • rpf65
    rpf65 Posts: 2,127
    Of the three you listed, I would go with the Denon.
  • rooftop59
    rooftop59 Posts: 7,973
    Denon will be fine. Avoid the others...
    Game Room 5.1.4:
    Bedroom 2.1
  • French_guy
    Yeah, I thought Denon would be the best pick...
    How does the new S940H compoare with the x2400h by the way?
    No surround...yet
  • mdaudioguy
    mdaudioguy Posts: 5,165
    French_guy wrote: »
    X series is better made than S, with an additional year warranty and better calibration software. If you can afford the S940, buy the X3400H.
  • French_guy
    Both S940H and X2400H are under $350 on A4L, and S940H comes with Multi EQ when X2400H comes with Multi EQ XT
    X3400H has Multi EQ XT32, but price is $500
    So X2400H seems to be the best compromise after all.....
    No surround...yet
  • rooftop59
    XT32 is much better if you can swing it...
    Game Room 5.1.4:
    Bedroom 2.1
  • rpf65
    rpf65 Posts: 2,127
    French_guy wrote: »
    The $500 buys you a few things. Better calibration program as well as a better power supply, things you don’t really see but are important none the less. This is true for all manufacturers. As the units move up the food chain, build quality and internal parts become better, even if you see similar features.
  • French_guy
    Well, i can still wait a little, hoping A4L makes a discount on the 3400 for the New Year.....................Who knows ???
    No surround...yet
  • rpf65
    rpf65 Posts: 2,127
    This is also the time of year with a lot of returns, so may want to check open box at various retailers.
  • French_guy
    Good point, I can go take a look at some Best Buy around me....
    No surround...yet
  • mrloren
    mrloren Posts: 2,454
    Yeah I would go for the 3400 if you can, It has preouts if you want to add an amp later
