Speaker + cable advice for old Parasound system
cortico
Hey folks, I have put together an older Parasound separate system:
-HCA 1200II power amp
-P/HP 850 pre amp
-C/DP 1500 cd changer
-D/AC 1100HD Dax
-Pioneer PL530 turntable
Currently using blue jean ICs, Linn K20 speaker cables and Mercury Magnetics 12awg power cords and Jennings Reseach contrata pedestal speakers. I really like this rig, I would be cool to get another power amp and run one per Chanel, that would be a killer set up!
I definitely prefer warmer sound with mellow hi freq, I was thinking in getting new speakers/cabling. what would you recommend.... new, old?
-P/HP 850 pre amp
-D/AC 1100HD Dax
Audioquest Evergreen ICs and Type 2 or Type 4 speaker cable.
Thanks clipart! 👍🏼
I am willing to experiment with phono preamps as well, the php 850 built in phono is sounding a bit mor analytical and cooler in comparison to the Marantz 1060 phono, maybe I am still getting used to the new sound. -
Nice looking system!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Tanks man, I really like the look too and sounds good! I made a quantum jump from the 70s to the 90s, still love my vintage Marantz gear, though!
Do these all have balanced connections? I am going to be listing some Pangea True Balanced Premier SE Cables soon if you would be interested. To me they were comparable to my Audioquest Columbia interconnects.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Speakers: Golden Ear Triton Reference
Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90/JBL SDP-55
Amps: Parasound A31, A51x2
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
You need to match that system with some big old school floor speakers. If only I could think of a brand..........
Start with the Monitor 10a with the Peerless tweeter. Then when you Bi-Amp start looking at the SDA's -
Hey sgmsmg, thanks for the offer, only the dac has balanced output, all the rest is RCA
No problem. Did not have a chance to look up your components. I am sure someone here will be able to help you out.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Thnx, Tony
PS: Sorry for the thread derail
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
@gp4jesus I sent you a message.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
