Line Input Switch
verbverb Posts: 10,313
edited December 2018 in 2 Channel Audio
Not much here on CP, but anyone using a switch to select multiple inputs to a amplifier? In my case, I've got the Bottlehead SEX integrated, which only has a single input. Any advice or experience is always appreciated!
For reference, I found this. 4 inputs, single output. Looks solid, with no sophisticated circuitry to muddle things up.
Luxman AS-4III
Basement: Polk SDA SRS, Cary SLP-05 Pre with ultimate upgrade,Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Cambridge 851N streamer, Marantz SA-14 SACD, McIntosh MC300 Amp, Silnote Morpheus Ref2 Digital Cables, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner
Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
  • BUT IT WILL MUDDLE UP THE SIGNAL!!!!
    Idk what i'm talking about. Looks cool and the simple circuitry I would figure is the most you could ask for in your situation.
  • delkaldelkal Posts: 738
    How often do you change sources? I listen to CD's 95+% of the time and have no problem unplugging an RCA cable.
  • verbverb Posts: 10,313
    delkal wrote: »
    About 50/50 between the CD and the streamer. And maybe the cassette deck in the future!
    verb wrote: »
    delkal wrote: »
    Then you should probably get a switch. It would take a long time but I wouldn't want to wear out the RCA connector.
    But a cassette player? You should edit your previous post so you don't incriminate yourself. Hooking up a cassette player to a Bottlehead Sex is illegal in most states and will instantly void your warranty. :D
  • DaveHoDaveHo Posts: 2,935
    Maybe a Schiit SYS if you only need two inputs.
    schiit.com/products/sys
    delkal wrote: »
    verb wrote: »
    delkal wrote: »
    Au contraire my dear @delkal ! Have you not been keeping up? :smile::wink:
    https://forum.polkaudio.com/discussion/180346/are-cassettes-really-making-a-comeback/p1
  • BlueFoxBlueFox Posts: 14,118
    verb wrote: »
    Yes, but I use a pre-amp to switch sources.
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    DaveHo wrote: »
    Looks nice! Thanks Dave! Price is right too.
  • mhardy6647mhardy6647 Posts: 26,914
    In a word, yes.
    verb wrote: »
    DaveHo wrote: »
    I use one in a secondary bedroom system in place of a powered pre. Seems pretty transparent to me. In your use case, with the volume control turned fully up & essentially out of the loop, I can't see it negatively impacting things.
    My "passive preamp" (transformer volume control) also has a three position source selector in front of it -- but I also use a keen little "Azden" branded switch unit which also provides some dubbing facilities (for those of us old enough to remember dubbing -- sort of the analog ancestor of ripping ;) ). I had the opportunity to buy two of these units at a charity fleamarket in our erstwhile home town some years back. I only bought one. Shoulda bought both. :|
    24678440802_27114f1d77_h.jpg009 by Mark Hardy, on Flickr
    passive to the left, Azden switch box to the right. Sorry the photo's meh. ?Danged black faced components are hard for tyros to photograph.
    24500746450_22ef21fa9c_h.jpg010 by Mark Hardy, on Flickr
    ... or of course, there's always the nuclear option.
    24770045716_11ec7d3c13_h.jpg011 by Mark Hardy, on Flickr
    24770042506_c3d355ea2c_h.jpg014 by Mark Hardy, on Flickr
    one of these'd be really cool, but I've never seen one of these in the wild. :( This one was acquired by someone on AK a while back.
    Gotta love the internet! For sale currently:
    That one has some active circuitry in it, too! :p
    My guess (?!?!?) is that the switching part is completely passive -- but it may in fact be a little mixer (mixerette)?
    A passive switchbox is easy to make and it only adds one extra RCA plug and a switch to the signal path. If you like to tinker there are numerous plans on the internet. And with quality components you can probably make something better.
    Here are some basic examples using a double pole rotary dial. Note all of the RCA plugs are grounded to the box. This design is simple but I would prefer to also switch the RCA ground too. This can potentially reduce noise or ground loops. If you use a 3 pole switch where you switch ground you will need insulated RCA plugs so they are not all grounded on the box (or a plastic box).
    flickriver.com/photos/wstryder/sets/72157626118016247/
    dreaminginbits.com/rca-switch-box/
    Rotary switches work fine but if you only wanted to build a box for two inputs I would go even simpler and just use a triple pole double throw switch.
    delkal wrote: »
    Very cool! Thanks! :smile:
    I found this interesting guy. Tisbury Audio. Made in England. 3 inputs, 2 outputs, all reconfigurable. Looks very well built!
    https://tisburyaudio.co.uk/mini-passive-preamplifier
    sure does.
    Might I, however, suggest -- with, of course, characteristic humility :| -- that, if you want to go the 'passive preamp' route, you give some consideration to a transformer or autoformer volume control as opposed to a resistive atenuator? :)
    verb wrote: »
    Looks nice....But you don't need passive volume control for your setup. Sure you can bypass it but you are paying for something you don't need.
    All you need is something like this. $38
    https://bhphotovideo.com/c/product/718845-REG/Sescom_SES_AUDIO_AB_SES_AUDIO_AB_RCA_Stereo_Audio.html
    This switch looks heavy duty and from the style is probably old. There is a good chance it was made in the US. Unfortunately there is no description of who made it. But for $27 it looks better than the junk on amazon.
    It is item SSS-1 STEREO AUDIO LINE LEVEL SWITCH-3 INPUTS TO 1 OUTPUT (REVERSIBLE)-USES RCA PLUGS
    https://electronicplus.com/content/ProductPage.asp?maincat=as&subcat=aau
    Interesting Doc, as always.
    The volume control on this unit was really not intended for primary use, as the Bottlehead's volume control will be. As such, the passive's attenuator would generally be "turned all the way up" while in use. Would that mitigate the negatives associated with the resistive type attenuators?
    delkal wrote: »
    verb wrote: »
    That is a cool site! Lots of cool stuff in there! Thank you sir! :smile:
    verb wrote: »
    I agree with the sentiment that if you don't want to go the 'passive preamp' route, that you should just avoid having an attenuator in the gizmo, full stop. :)
    Along those lines, there's - IMO - nothing wrong with the cheap passive switch boxes that used to be sold, e.g., by the defunct MCM Electronics. MCM still sort of lives on as part of Newark, but to actually find any of their legacy products on the "Newark Element14"* website is a Sisyphean task. :(
    https://www.newark.com/mcm/50-6175/switch-box-four-input-source/dp/39C0728?MER=bn_search_1TP_SearchNB_1
    ______________
    * Dafug is Element14 all about, anyway? I mean, element 14 is silicon, but it ain't a computer company, you know? :/
  • erniejadeerniejade Posts: 5,470
    DaveHo wrote: »
    I am using one on my KEF ls50W to go between the Lumin D1 and Jolida d9 phono pre. If the volume is all the way up on the SYS, I cannot hear the difference between the Lumin strait to the kef, or going through the sys to the kef but, I do have decent cables on it.
    Den: Lumin D1,Wireworld Silver Eclipse RCA, KEF LS50 Wireless, Velodyne SPL1200, Technics 1200, Denon DL160, Jolida D9,
    Living Room:,T+A PA 1530R,Wireworld Silver Eclipse SC, Tyler Highland H2, High Fidelity Reveal RCA, Innuos Zen MK3 , W4S recovery, LKS MH-da004,
    Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T, Grant Fidelity Tube Dac11,Aries Mini
    Interesting pieces by Yamaha and Pioneer.
    At the time I suppose when the number of popular input devices clearly exceeded the capability of controls amps at the time!
    Yamaha AVS700:
    Pioneer AVS700 (funny that is has the same model number as the Pioneer):
    edited January 2019
    So I went with the Tisbury passive pre. Got a great deal on a used minty piece. Gotta admit, the aesthetics match nicely. Playing right now!
    3 inputs, 2 outputs, and a volume attenuator.
    verb wrote: »
    Yamaha AVS700:
    oooh, I want one o' them Yamahas! :)
    awww, man... that's cruel!
    Muhahaha! Do it Mark! :smile:
    It does, sadly, have an owwie on the front panel -- otherwise it'd already be on its way here! :)
    Aw man. Good catch. There are others, but more expensive! :smile:
Howdy, Stranger!
