Acoustic Panel Build
13»
  • machone
    machone Posts: 1,564
    Thanks Mike
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I pushed the speakers back another 1/4" closer to the wall. Not impressed. Undid the move.
    Then I moved them 1/2" further apart. Best so far.
    Also, I am using a string across the baffles to make sure they are parallel.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I pulled the speakers out from the wall another 1/4". Better sound stage and cleaner, stronger bass.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • K_M
    K_M Posts: 1,631
    txcoastal1 wrote: »
    Here are some I built for LSAF. Stands are made with black pipe and base filled with lead shot.
    That looks quite similar to what we made for one room.
    Was that Roxul from Home Depot by chance?
    txcoastal1 Posts: 13,519
    K_M wrote: »
    txcoastal1 wrote: »
    The Dyn's being rear ported and the walls at LSAF are concrete so I needed something for the bass....I used this
    https://www.acoustimac.com/ecoinsul422
