Hafler 500 Upgrade
  • motorhead43026
    Sweet, some serious capacitance going on there. That thing is going to be a beast once you are done.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • machone
    machone Posts: 1,475
    edited December 2018
    Got the board, rectifiers and components for the power supply upgrade.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I installed the ps upgrade last night.
    Removed caps, rectifier and installed standoffs.
    Board populated and tracks filled with solder.
    PS installed.
    Fired it up with a variac and checked the ps output voltage, all good. Installed the driver board fuses and checked the bias, all good less than 5mv.
    Put back in the rack and fired it up.
    I am impressed. No noise, very musical and rock solid but very delicate at the same time. These modern capacitors are quite amazing. Definitely more tactile bass while cymbals slowly decay and recording room ambiance is enhanced. I could not be happier.
    I had goosebumps with body rushes..... :):)
    I am out of town for the weekend and can't wait to get back and listen some more.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • gp4jesus
    gp4jesus Posts: 1,969
    Thanks, I really want to get the XL600 freshened up. I love these big Haflers.
    a side benefit to doing PS upgrades* in the XL 280s & 600s is they come from Hafler w/separate rectifiers & cap banks for each channel making the aforementioned* easier.
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • gp4jesus
    To the OP: did MC provide the wire to connect to the binding posts or did you reuse? In my XL280 I found subtle & not-so-subtle improvements using better/heavier wire for the above & PS caps to driver boards.
  • machone
    I replaced the wire B-B+ from the ps to the driver boards but not the wire from the driver boards to the speaker posts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I got 150 hours on the PS upgrade.
    It's really really good.
    Smooth as silk.....
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Just hit 300 hours.
    Really opened up with a powerful bottom end. Wrap-around 3d soundstage. I did not expect this upgrade to have such a positive impact on SQ. I am pleasantly surprised.
    Do these 2.3TL's have a limit !?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I replaced all of the wire running from the power supply to the driver boards and from the driver boards to the binding posts with 12 awg. Also, I replaced the 35 year old thermal paste under the MOFETs. B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Clipdat Posts: 12,606
    What type of thermal paste did you go with?
  • machone
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Well, after rewiring the power supply to driver boards, driver boards to speaker posts and replacing the thermal paste under the MOSFETS the amps mojo fell off. I had an oops o-carp moment. :'(
    250 hours later the mojo is back in spades. It took that long for everything to settle and burn in! :)
    It is sounding great B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    audioluvr Posts: 5,437
    machone wrote: »
    What wire did you go with?
  • machone
    What wire did you go with?[/quote]
    I got it through Musical Concepts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • MarkTMeyer
    Hello, any further updates or impressions? Anything you would differently? btw : where did you purchase the oslo power switch, is it lighted?
    Thanks!!
  • machone
    I've had a lot of fun and learned a lot upgrading the Hafler. Very little original except the chassis and mosfets.
    I would not change a thing but I would like to try Musical Concepts new PA7 frontend someday.
    Got the HD lighted switch from Musical Concepts.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • MarkTMeyer
    Just upgraded my speakers to Acoustat 1+1s , My Musical Design D75 dies, and I'm digging out my old DH500. Had purchased many years ago PA-3b boards and dual mono transformers. Going to use the PA-3B boards , transformers, and update to the most recent MC dual mono board and Mundorf 15,000 Caps. Anxious for the parts to arrive to get started. Ordered Mundorf 1500 caps for the on board PS for the PA-3B, will have the Mundorf and a set of Blackgates for the other caps on board. Will run these for a while until I can upgrade again to PA-7s.
  • machone
    The power supply is a definite upgrade. I think you will be pleased. I also added an IEC socket and upgraded the power cord.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • MarkTMeyer
    Have mogami wire to construct power cable, along with Connex Power/IEC Plugs Rhodium-Plated Copper , along with IEC rhodium /copper receptacle.
  • levier
    levier Posts: 2
    Machone... I have recently purchased a working DH500, planning the exact upgrades you have done. How is documentation/ instructions from John? I have experience rebuilding, upgrading Dynaco ST400, with success, pretty sure I can follow good set of instruction.
    Did you have any issues getting responses to questions? Not familiar with filling solder tracks, is this a hot plate or oven procedure?
    Thx...
  • machone
    Excellent instructions and support. John knows Hafler. I used a soldering iron to heat and fill the tracks with solder.
    Have fun!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • levier
    levier Posts: 2
