digital coaxial cable
marvda1
great sounding cable. sounds best bnc to bnc and if you need rca get adapters.
https://www.amazon.com/gp/product/B01N4UMC4N/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01AGOMWPU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
what's your best bang for buck coax cable?
Puritan PSM156
Puritan PSM156
Belden 1694A from Blue Jeans cable. Clean, neutral, and most importantly spec'd correctly for digital transmission. Been using it for years with no desire to replace it.
https://www.bluejeanscable.com/store/digital-audio/index.htm
A whopping $18.95 for a 3ft length.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
A guy here locally on CL has:
AQ cinnamon for 30 bucks
Silnote Audio Morpheus Reference II Series II for a hundie.
Gonna check em out tomorrow.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Signal Cable, Silver Resolution.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
is the silnote bnc or rca?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I've used the Belden 1694 for interconnects for audio and video. No problems very versatile cable. -
Have been using the Supra Trico and have been happy- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
see the guy only wants local pickup :'( , anyone willing to pick one up and ship to me?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
which one you getting? if audioquest would you pickup the silnote and ship to me?
i can send funds paypal.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Blackcat veloce is a great budget digital coax.
I'm still using an Audio Metallurgy GA-0 coax digital, and haven't found anything that bests it yet. Been in the system for roughly 10 years too. Also have an MIT AVT digital coax around here somewhere, and that one , while also a good budget cable, can't keep up with the GA-0.HT SYSTEM-
lsi 9's -
That's one of the cables I reviewed for the three way digital coax cable shootout review that I'm working on. It went up against Douglas Connection Bravo and AQ Carbon.
I bet you can guess the results. -
The DH Labs D-75 is another budget ($65/mtr) over-performer.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I couldn't find a 75, but the 750 is $90 for .6 and $130 for one meter fyi...while it may well offer great bang for the buck, I'm not sure if I would call it budget...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
i've got the black cat silverstar mk1 coming that replaced the veloce and if it is good i might consider the silverstar mk2 that runs $325 for 1m.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Cool Marv, I'd be very interested to hear your comments on the Silverstar.HT SYSTEM-
lsi 9's -
just bought this used, killer dac, that's why i'm trying to get the best(affordable) digital cable within reason.
https://www.shenzhenaudio.com/l-k-s-audio-mh-da004-dual-es9038pro-flagship-dac-dsd-input-coaxial-bnc-aes-ebu-for-dop-usb-i2s-optical-audio-decoder.html
Puritan PSM156 -
Hey @marvda1 I got the Silnote and the AQ. I’ll run with the Silnote and keep the AQ as a spare.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
If you change your mind you know where to send the silnote
Puritan PSM156 -
Will do sir!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
@marvda1 I thought I posted this, blame it on vanilla! Or user error
https://www.ebay.com/itm/SILNOTE-AUDIO-MORPHEUS-REFERENCE-SERIES-2-AWARD-WINNING-DIGITAL/332940938766
A little more that what I paid but well below retail.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
