New car new system
Looking to put a system in my "new" car. 94 mercury sable. Calls for 6.5s and 5x7s. Have an nvx jad 800.4 4 channel. Outputs 125x4 at 4 ohms. What speakers would pair well. This does use the same internals as one of the polk amps.
HT/2channel:
AVR: Yamaha RX-V 765
Fronts: Polk RTiA3
sub: Polk PSW110(will add 2x PSW 505)
Center: CS13
surrounds:Polk RTi4( also have some def tech pro Mon. 800s, may end up her or expanding this to 7 channel.)
TV: samsung 40
The real 2 Channel(work in progress):
Pre:HK 3490
Amp:Parasound 1200 MK II
Sub:RBH 1010-SEP
Speakers: Monitor 5A peerless
Headphones:
Source: FIIO X3 CD rips WMA lossless
Amp: FIIO E12, Nuforce icon udcac-2 W/pangea cable
Cans: Audio-Technica ATH-M50, Velodyne V-True, Grado SR225i
most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know :)
"WITH WILLING HEARTS AND SKILLFUL HANDS,
THE DIFFICULT WE DO AT ONCE,
THE IMPOSSIBLE TAKES A BIT LONGER
WITH COMPASSION FOR OTHERS
WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"
Seabee Memorial, Arlington, VA
  • Tony MTony M Posts: 7,608
    check "Crutchfield" for all your car audio needs. ;)
  • FestYboyFestYboy Posts: 3,435
    Before you worry about tunes, replace the rear struts and springs before they break on you. That is unless you like the saggy a$$ look. Make sure there's no front subframe rot too...
  • seabeerob213seabeerob213 Posts: 1,753
    edited December 2018
    Been on there, just hoping that you guys would have recommendations on matching amps to speakers
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
  • The car is in great shape, 1 owner car and well looked after. Grandpa gave it to me. Will be doing ball joints and bushings soon though. gmvtzqqss3cq.jpg
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
    That's not too super critical in car audio (amp matching). I'd focus on the front with some components and add a 8" sealed sub. Don't forget sound deadening.
  • Got a box of dynamat or the like, the mercury is already heavily deadened at least in the rear deck lid. And im thinking dual 10s in a ported box, as I have them already and 1200 rms.
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
  • And components are the route i plan to go. Just was told by a friend who does car audio for a living that that amp is too much for most speakers.
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
  • rooftop59rooftop59 Posts: 5,254
    At least in home audio, there is really no such thing...
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio NovaPre; B&K TX4430; Bryson BPD-1; Mains: Dynaudio Emit 10; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - HSU VTF-2 MK5; LG UP870 4K BDP; NVidia ShieldTV
    Master Bedroom
    Marantz SR-5007; Parasound HCA-1000A, PSB Imagine B, NHT Super One CI surrounds, Martin Logan Dynamo (original), Squeezebox Touch
    That is BS, most quality aftermarket speakers will be perfectly fine behind that amp. Most amps today don't hit their rated or advertised numbers without clipping. If you care about SQ at all, cut the number of subs in half and build the best box you can for it.
    FestYboy wrote: »
    Custom box for my 10w7 is in the works, after i get it rebuilt. And ok, fair enough, will get what seems to be a good buy and a good speaker.
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
  • Yeah the hard part about car audio is no way to audition before hand. The good part, it doesn't matter as much compared to home audio.
    Polk makes decent speakers, Focal is good. I enjoy my RE Audio Reference components, the silk dome is a great tweeter. I find there has to be more synergy between head unit and speakers than amps.
  • Just a dude doing dude-ly things
  • I enjoyed Polks in two different cars over the years
    Living room Home theater: Upgrade Company modified Onkyo PR-SC5509,Sunfire Cinema grand Signature 5 channel amp(1st gen),Carver TFM-45,Carver M-400a,Panasonic TC-P50ST60 50" Plasma(last gen before Plasma production stopped)Pioneer Elite DVL-91,Meridian 519 Dolby AC-3 RF Demodulator,Oppo Digital UDP-205,TiVo Bolt VOX,Nakamich BX-300,Technics SL-1200MKII,Shure V15 Type VxMR cartridge,Polk SDA-SRS 3.1 TL(with RD-0198 tweeters, upgraded with Larry's rings, black hole5,an Avel-Lindberg 1000VA isolation transformer, VR3 customer crossovers and internal wiring),Polk CS-1000P(with SL-6506 tweeter),Polk Monitor 5jr(with RD-0194 tweeters),Polk RT-35i (1),Polk Mini Monitors,Polk PSW150(4)Monster Power HTPS 7000 MKII Signature series,Monster Power AVS 2000 Signature Series,Various MIT,Monster,Upgrade Company and Belden interconnect,power,HDMI,Coax and Toslink Digital and speaker cables.
    Bedroom 2 channel system:Integra DTM 40.4,Nakamichi BX-100,TiVo mini,Musical Fidelity X-LPS,X-PSU,Carver TFM-25,Sony KV-34XBR970(last of the widescreen tube sets before production stopped)Technics SL-1200MKII,Shure V15 Type V MR cartridge,Polk RT-55(with SL-6506 tweeters),Polk PSW-200 in plexiglass(2),Sony Playstation 3 slim.Monster Power HTPS-7000,Monster AVS-2000, PowerVarious Kimber,Audioquest and MIT interconnects and speaker cables.
  • Right now I just have an old Kenwood head unit I had laying around, and some rockford prime 6x8s driven by the head unit just to replace the dry rotred paper cones in back. Will hold off on the fronts till I double din and amp and get something I know will be good up there. Looking at ct sounds digital designs, but ill look into those cody suggested, and polks are always an option.
    HT/2channel:
    Fronts: Polk RTiA3
    Center: CS13
    TV: samsung 40
    Pre:HK 3490
    Sub:RBH 1010-SEP
    Headphones:
Howdy, Stranger!
