VGA Monitor Cables
cfrizz
in Electronics
Hi guys, I just got a new monitor for Christmas, and after awhile the screen turns yellow. I want to switch out the VGA cable to see if that solves the problem.
What I don't know is if they are interchangeable, or if I have the use the cable that came with the monitor.
Any help would be appreciated.
Go digital if at all possible. DVI, HDMI, Display Port, etc.
Thank you, but that doesn't answer my question, I'm trying to work with what I've got.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
VGA cables are interchangeable, they are not monitor specific.
VGA Cables should be interchangeable. I've had brand new monitors arrive DOA though, or with issues. Hopefully you can return it if the cables don't fix the issue.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Cool thing I learned about VGA: it is capable of better than 4k resolution...
As said above they are interchangeable. If a new cable doesn't help return the monitor like Verb said.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
I switched it out, cross your fingers so far so good!
As always thank you for your help.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I hooked my monitor up with an HDMI cable and it looked washed out. Changed to a VGA and the colors are brighter and picture is sharp. Really thought it would be the other way around. -
Yeah I did too until I had to hook up my projector through VGA and was concerned it wouldn't handle 1080p... Boy was I wrong.
