Cross-over upgrade
I think it might be time to upgrade my cross-overs. I found an old link for a SDA SRS X-over parts list but it seems to be broken. Am I better off rebuilding the X-overs in the speakers or going with an active system?
    F1nut Posts: 49,805
    Do the crossovers. You won't believe how much better your speakers will sound.
  • [Deleted User]
    Thanks. Do you happen to know where i can find that parts list?
    F1nut Posts: 49,805
    Sorry no. You can find all the values on the posted schematic or pull a crossover and get the values off the components.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    If you use Gimpod's website, you can look up the schematics under the schematic link...
    http://gimpod.com/
    VR3 Posts: 28,050
    Sda srs is not gimpod compatible
