Cross-over upgrade
I think it might be time to upgrade my cross-overs. I found an old link for a SDA SRS X-over parts list but it seems to be broken. Am I better off rebuilding the X-overs in the speakers or going with an active system?
    F1nut Posts: 51,770
    Do the crossovers. You won't believe how much better your speakers will sound.
  • Thanks. Do you happen to know where i can find that parts list?
    F1nut Posts: 51,770
    Sorry no. You can find all the values on the posted schematic or pull a crossover and get the values off the components.
    VR3 Posts: 29,427
    Sda srs is not gimpod compatible
