Vitamix
tonyb
Anyone own one ? Talk to me....what's the best model/series ? My in-laws have the 7500 and would have sex with it if they could. I was thinking the 5200-300 series. People rave about these things but all I read is problems with black plastic specks, breaking down, and poor CS. Set me straight.
I use the ninja. Cheaper and just as effective; I have used bothShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I have a blendtec total wild side+. Works pretty darn well for our needs (mostly smoothies). Friends had their jar start leaking after several years, called customer service and got a new shipped out free until warranty. Reputation for good CS...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I have a vitamix 6500 and love it. Had a ninja before and the comparison between the two isn’t even close in my opinion. Votamix has good refurbished deals, picked mine up directly from them refurbished 4 or 5 years ago and never had an issue with it2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Need something for that aging prostate, eh Tony?
Centrum works better imho... and without the mess.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
@tonyb,
My wife and I have owned a Vitamix Professional Series 750 for about a year. I use it every day, and my wife uses about as often. We have not done anything really "heavy duty" with it. We have had no problems. Prior to purchasing it, we used a Waring Commercial blender, and the Vitamix runs circles around it with respect to power for mixing, chopping, pureeing and, especially, liquifying and with respect to the smoothness of the result (if you are aiming for smoothness). We bought a large and a smaller blending container, and we find both useful.
I did quite a bit of research before making the purchase. My daughter pushed for the Vitamix because she has used one for years and swears by it. A good friend who is really into smoothies highly recommended a Blendtech model (whose number or name I do not recall). I finally purchased the Vitamix because I got a better price for the comparable model.
Both the Vitamix and Blendtech are noisy. Blendtech sells models with a noise dampening enclosure that cost more. My wife makes me wear hearing protection when I'm running the Vitamix because she thinks my hearing is already compromised -- that is, she is convinced that I play music louder than she likes because my hearing has been compromised.
My opinion is that either the Vitamix or the Blendtech machines are a quantum improvement over standard blenders, but that differences between the performance of the Vitamix and Blendtech are likely to be immaterial.
Just MHO.
PS: Yes, @nooshinjohn, I use it for blending pomegranate powder into orange juice because pomegranate powder is reputed to be good for those with prostate cancer. Pomegranate powder is very sticky, and my ordinary blender left both clumps of it in the blend and blotches of it on the sides of the container.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Google "will it blend?" and watch the videos on Youtube. It will entertain you for hours.
Don't breath this.............
But be warned. A Vitamix will seem lame in comparison, -
Thanks for the input guys.HT SYSTEM-
lsi 9's -
How good is it at whipping up a batch of frozen margaritas that's the real story here?
We have one, the Pro 500 that we bought as a refurbished unit. Warranty is 5 years instead of 7.
My BIL has the Ninja...the big one, not sure which model it is...no comparison imo...plus the ninja is a pita to clean.
You can dump in peanuts only and it will make peanut butter. Also, it spins so fast it will make hot soup from just the friction of the blades.
We debated both the Blendtec and the Vitamix, hard to go wrong but we have zero complaints.
There are models with the larger jug which sits lower and will fit under the cabinets if that's a concern. The blades are larger on the wider jugs which also use a slightly stronger motor, I dont think you can use the small, wide jug on models with the taller jug...just a heads up.
Having had experience with both Vitamix and Ninja I will echo the sentiments of others here...there is no comparison (at least not one that's good) between the two. Vitamix is top notch, Ninja uses a lot of cheaper parts and have many issues. Just google issues with Ninja and see what comes up. If you're going to use one occsionally then the Ninja may be fine. If you want to buy one you can use daily with little to no problem then go with the Vitamix. Have no experience with Blendtec.
Three 20 amp circuits. -
Here you go: Vitamix 5200 for $299
https://www.amazon.com/Vitamix-Blender-Professional-Grade-Container-Black/dp/B008H4SLV6/ref=as_li_ss_tl?ie=UTF8&linkCode=ll1&tag=cnetdeals_nl-20&linkId=c280885615a6de8059473c8b0fc00ca9&language=en_US&ascsubtag=___VIEW_GUID___
HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
T
I've got an older 5000 series that in a word is a "workhorse"
If you can get one, prolly a refurb, I wouldn't hesitate. No advanced electronic to go wrong (tho, when they're working right, they work well)
This thing is Geo Forman pounding the daylights outta anything you throw in it. No issues, except for the order in which you add ingredients. That is just a learning curve. No biggy
Going strong for 'bout 10 yearsAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Is be tempted to go with this one:
https://www.amazon.com/gp/aw/d/B01688AFFC/ref=sspa_mw_detail_1?ie=UTF8&psc=1Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Here’s the blendtec I’ve got. Works great!
https://www.amazon.com/Blendtec-Professional-Grade-10-speeds-Certified-Refurbished/dp/B00TKRQWS8/ref=mp_s_a_1_4?ie=UTF8&qid=1544233995&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=blendtec+wildside&dpPl=1&dpID=41GKlxTM9+L&ref=plSrchLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Had ours for over 8 years now. Had one replacement container because we messed up when putting back together one day (and Vitamix covered the whole cost)
Great company. -
FYI several blendtec machines are on sale on amazon. The one that I own is $100 cheaper than I paid a few months ago!!!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
stangman67 wrote: »Vitamix has good refurbished deals
I just purchased a refurbished one for my wife for Christmas with full warranty at half price. It will be her first Vitamix but I have high hopes.
https://m.youtube.com/watch?v=4AZK2-Tfc84
