Speaker purchase
PeteD
PeteD Posts: 19
edited December 2018 in Speakers
Currently running Fronts TS1 500, Centre CS20, Sides TS1200, Surround backs OWM3.
Just bought Denon AVR-X4500H want to set up heights front an side. What would be best up there. Thinking of (4) OWM 5s or OWM3s like i have at the back.
Best Answers
  • FestYboy
    FestYboy Posts: 3,861
    Answer ✓
    PeteD wrote: »
    I guess the real question for me is will that receiver putting out 125W for surround back/Height 1&2 channels damage the OWM3 showing continuous power 100W. I have the crossover for those speakers at 120, with fronts at 80
    Your receiver will never put out that much to your surrounds, so don't worry about that part.
    tonyb Posts: 32,906
    edited December 2018 Answer ✓
    PeteD wrote: »
    The receiver will be fine, those extra speakers are for ambient noises, no real power hungry aspect of a movie is really used for those. Adding more speakers though takes that much more power away from the rest.
  • rooftop59
    rooftop59 Posts: 7,986
    Answer ✓
    @PeteD first, your receiver won't put out 125 WPC for more than 2 channels driven. Those Denon's do bench test pretty well, but at most its putting out 90-100 7 channels driven, the more speakers you add and it might drop even more.
    Second, you can almost never have too much power for speakers. Most damage comes from under-powering them. And since those surrounds are mostly for ambient sounds, there is even less of a chance. No problemo...
    Game Room 5.1.4:
    Bedroom 2.1
Answers
    tonyb Posts: 32,906
    That's probably your best bet. Before you run out and buy more speakers, do you actually watch movies from a Blu-ray disk ?
    The reason I ask, is because that's really the only format that will allow those extra speakers to be used. If your movie watching is from cable TV, Amazon, Netflix, they don't carry any of that extra decoding so you'd be wasting coin.
  • rooftop59
    And not just BDs, but a 4K player that can send Dolby atmos. They don’t all have to be 4K discs (a number of BDs have atmos soundtracks), but the player us to be 4K to even bitstream atmos.
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    Yea and although I am not a fan of those speakers, I think they are fine for atmos. Mostly ambient sounds I think...
    Game Room 5.1.4:
    Bedroom 2.1
  • PeteD
    PeteD Posts: 19
    Home theatre set only movies with Blu Ray player and 4k Samsung 65" TV
  • rooftop59
    Is the BDP 4K? Cause I think that only a select few non 4k BDPs will process atmos
    Game Room 5.1.4:
    Bedroom 2.1
  • PeteD
    PeteD Posts: 19
  • PeteD
    PeteD Posts: 19
  • mrloren
    mrloren Posts: 2,456
    rooftop59 wrote: »
    My older Oppo will bit stream ATMOS/DTS-X
    Most modern players will bit stream the new formats.
    No sub in the OP setup ?
  • PeteD
    PeteD Posts: 19
    Thanks guys for your input.
