AVR upgrade advice!
124»
  • polkerfan
    You betcha, Clip. Thanks!
  • FestYboy
    FestYboy Posts: 3,861
    Fantastic, now get a good pair of subs and post a review.
  • jeremymarcinko
    Nice!
  • polkerfan
    SYSTEM UPDATE! So, guys, after ALOT of research, and considering all of the advice you guys gave (which I truly appreciate), I decided on the DEFINITIVE TECHNOLOGY Pro Sub 800 as my sub choice. Was able to hear it personally, and was extremely impressed. Small size, quality of build, room size and price point made the decision easy. Now, I have questions as to the best way to hook this sub up to my system. Of course, using a high quality sub cable plugged into the LFE jack, in my understanding, is best for movie listening. But there is this option for 'high level' speaker wire connections, which would involve running separate left/right wires from avr to sub, and then left/right wires to SUB from each tower speaker. Considering I want the best low end for movies AND music, what is the BEST way to go about this?
  • mrloren
    mrloren Posts: 2,488
    The speaker level input is for if your AVR does not have an LFE or SUB out. Set you AVR to LFE+Main in the sub settings. Set your speakers to small and cross over to 80hz. Let the sub play the low end as it was made for it.
    Not a bad sub, at least its better than no sub. You should have given SVS or HSU a shot but for the price it's not bad.
    Family Room:LG QNED80 75", Onkyo RZ50 Emotiva XPA3 GEN3 Oppo BDP-93,Sony UBP-X800BM. Main: Polk LsiM 705 Center: Polk LSiM 704CFront High/Rear High In-Ceiling Polk 80F/X RT Surrounds: Polk S15 Sub: SVS SB-17 ULtra
    Working Warehouse; Denon AVR-3312ci , Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music
    Clipdat Posts: 13,106
    polkerfan wrote: »
    Use the LFE jack.
