Insulating garage door
13»
    VR3 Posts: 29,522
    Maybe you guys can do a club Polk buy... Every dog owner should have it...
    Waterproof, dogs feel secure in their cave in storms, warn in winter, cool in summer, comfortable safe place for the four legged minions!
    EndersShadow Posts: 17,716
    Here is my spring...
  • ken brydson
    ken brydson Posts: 9,015
    Newer torsion type...
    pitdogg2 Posts: 27,212
    Not the newer drill adjustable torsion spring.
  • steveinaz
    steveinaz Posts: 19,545
    edited November 2018
    If that's a double door, you "should" have 2 torsion springs, ideally. A lot of builders cheap-out by using only 1. After insulating, you'll probably need a 2nd spring for the right side.
    steveinaz wrote: »
    Its a 2 car garage with a single door. So I'm guessing your right.
  • Willow
    Willow Posts: 11,246
    steveinaz wrote: »
    I'll have to check mine out tonight. Oddly enough I went out for a drink with a friend Tuesday and he told me he got home one day and his door would only open about 3 ft. Turns out 600$ later new cables, new spring and rollers. Plus he found out the opener was not installed properly in the first place.
  • steveinaz
    It's not difficult to add a second torsion spring to a double-sized door.
    steveinaz wrote: »
    Have you met Dan? :#:#
  • lightman1
    lightman1 Posts: 10,797
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited December 2018
    I replaced my springs myself. Its no big deal; just pay attention.
    Maureene reported
