Tandberg TL 5010 Speakers
  • Update:
    Ordered Mills resistors from Sonic Craft and Dayton capacitors from P.E.
    Also ordered some of the P.E. speaker gasket material. I'm going to stick with the stock inductors to keep cost down for this project.
  • corticocortico Posts: 475
    No affiliation, sonic craft people are nice to deal with. Post some pics!
    Parasound HC/A 2200II < PL/D 2000 < DA/C 1100HD < CD/C1500
    Cambridge Audio phono pre
    Pioneer PL530 turntable, Shure M97XE cartridge
    Belden ICs
    MIT T2 speaker cables
    Polk Audio LS70
    "If it measures good and sounds bad, it is bad"
  • ConradiclesConradicles Posts: 5,771
  • lightman1lightman1 Posts: 10,086
    Ten pounds of bullpewp in a five pound bag, Eric.
  • mhardy6647mhardy6647 Posts: 20,610
    may need to extend the leads a wee bit on them Daytons ;)
    (or just rebuild the whole XO on a piece of perfboard or suchlike)
    Not seein' a big problem here (FWIW)
  • xschopxschop Posts: 948
    Can you alternate (over/under) the caps on the board and make taller standoffs for the board?
    Put one of the resistors on the backside to make it work:
  • Looks like a old farmer trying to stack his new round bales, cause how else do you get a haystack?
    Had some time on a rainy day today to get the other crossover completed. Sealed the drivers, added new mounting hardware, finished the cabinets and playing them now. Crossovers are burning in for a few days. Will report back in the future after I get some time with these classic vintage speakers.
    About 70 hours of burn in time now. I really appreciate these speakers!
    Hard to believe they are as old as me. The bass the 12" driver produces in the sealed cabinet is amazing. So natural.
  • Hello all. I am currently listening to a set of these here in Norway. I do dig them.
    The bass may lack some punch however, will changing the capacitors maybe remedy this?
  • Playing on the tr 1000 from same year.
    Saunier wrote: »
    I don't know for sure. Mine had extreme bass before the cap upgrade. Replace the driver gaskets 1st, and make sure there are no air leaks. These are some great vintage speakers. Hello in Norway @Saunier!
Howdy, Stranger!
