AVR upgrade advice!
24
  • FestYboy
    FestYboy Posts: 3,861
    If you need Bluetooth, there are stand alone receivers with optical out available... That's how I roll anyway.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    polkerfan wrote: »
    Also, I was told that as far as DENON receivers go, that there is supposedly NO difference sonically between the X1500 up to the X8500. Youre only paying the extra $$ for features. Is there any truth to this? Whereas recievers like the SONY ES and INTEGRA lines you pay the extra $$ for performance and better amps. Please clear this up for me.
    Just plain wrong.
  • Anyone else disagree with that salesman? I get that each increase in model will have a little more power, but are the amps or dacs better as you go up? Is the DENON x4500 BETTER than the X3500 sonically?
  • The fact is we’ve pointed you in the right direction based on our experiences. We can’t tell you what will be best for you, in your room, your speakers, and your preferences.
    Lots of good options there, some may last longer than others, which also depends proper care, ventilation, and level of abuse.
    You have some good options there, do some research, read the specs, decide what’s important to you and choose what suits you.
    As far as Bluetooth/WiFi they all have it or can be added.
  • FestYboy
    I agree, the salesman is wrong. Whenever the output increases, there should be a corresponding change in internals to cope with the higher output. Otherwise the bottom rung model would put out the same as the TOTL...
  • I guess what I’m trying to say is that, from what I was told, from say the X1500 and up, there is NO difference in the quality of sound. Sure the watts per channel goes up, but it doesn’t equate to cleaner, more detailed sound. Where as the SONY ES series, or Arcam there is a definite difference in amp quality, equating to better sound. Maybe I should shop elsewhere.
  • mdaudioguy
    polkerfan wrote: »
    You need to consider the source of the information.
    txcoastal1 Posts: 13,513
    edited November 2018
    mdaudioguy wrote: »
    polkerfan wrote: »
    I like to toy with the BB guys... :) makes for a fun day watching their head spin :)
    More fun was watching Russman when he worked at Magnolia toy with arrogant customers :D:D:D
  • mrloren
    mrloren Posts: 2,474
    polkerfan wrote: »
    Being a DENON guy for many, many years, it's hard to suddenly change directions. YAMAHA is definately an avr on my radar. I'd like to sacrifice alot of unnecessary features for bullet-proof amps and durability. Only feature I can't live without at this point is bluetooth and/or wifi. That's where I get all of my music. That being said, I believe Ive narrowed my choices down to the following:
    -MARANTZ SR 5013
    -DENON AVR-X3500H
    -SONY STR-ZA3100ES (no bluetooth/wifi)
    -YAMAHA RX-A2080bl
    So, not using price as any kind of factor, let me know what you all think of those choices. What is the BEST option here based off of actual performance. Everyone has opinions on what they believe is good- just provide me with facts so I can make the best decision. Thanks!!
    1. RX-A2080, this is a beast of an AVR
    2. AVR-X3500H Good AVR with Audyssey XT32
    3. Marantz SR5013 Good AVR but only Audyssey XT + Porthole display. Reason the 3500 is above it
    4. 3100ES, When Sony want to put their mind into making great audio gear they can out perform everyone else. Problem Sony has not done that in 20 years at the everyday consumer level.
  • mrloren
    polkerfan wrote: »
    Yes, Like Sir Skip said, more weight = more power supply with better boards.
    I too when board will go to BB and play with the sales guys. I asked about Polk Signatures guy tried telling me they were junk. He then tried to sell me these things with horns that sounded gross. I asked about Marantz AVR and he was trying to push me to Onkyo. I laughed he had Klipsch and Onkyo in stock. They just try to make the sale then and there.
    It's your money and time. BB does have a nice return policy. Get the one your leaning to take it home hook it up try it for a day and if you don't like it take it back.
  • mrloren
    3500H
    4500H
    Yeah I think there will be a sonic difference
  • That is awesome! LOVED your comparison list. I’ll keep you posted.
  • Ok, avr cage match- YAMAHA RX-A2080 vs. DENON AVR-X4500H!!!
  • mdaudioguy
    txcoastal1 wrote: »
    mdaudioguy wrote: »
    polkerfan wrote: »
    I like when you ask them a question and they immediately look at the info tag on the shelf (as if I couldn't read it myself)... :|
  • polkerfan wrote: »
    Dead even.
    I’d give the 2080 a +1 for build quality and then Denon a +1 for maybe a little better auto calibration.
    So if you know you like Denon then go that route.
    If you want to try something a little different then go with the 2080, otherwise both are fine AVRs.
    Maybe choose on price at this point.
  • mrloren
    Coin toss.
  • rooftop59
    rooftop59 Posts: 8,121
    Though they are not quite the same price point/level, when I moved from my Yamaha rx-a1010 to my denon avr-x4200w it was definitely a step up. The denon is so dynamic and immersive. Watched the greatest showman last night. Not the greatest movie but the soundtrack just rocked. Tonality, placement of instruments and voices in space, just awesome...
    Game Room 5.1.4:
    Bedroom 2.1
    FYI
    CES is 1st week in January
    Pending on the company...most electronics make the new year products shift at that time. Last years models become wholesale hence Super Bowl sales
    Pioneer was around June/July
  • Well, after alot of input from all of you (very appreciated!), and alot of research, I've decided to go with a YAMAHA RX unit. It's basically between these two units now- the RX-A1080 (which is $999 at BB) and the RX-A2080 ($1599 at BB). Is the 2080 worth the extra $600? Or are these two units virtually identical besides the extra two channel capability?
  • rpf65
    rpf65 Posts: 2,127
    Usually the difference between the 10xx and 20xx series Yamaha’s is extra channels, and a meaningless amount of power rating. You can probably compare them on Crutchfield’s web site. Don’t think the DAC until the flagship 30xx series.
  • FestYboy
    Stepping up to the 2080 allows Atmos output and all the nice things that go with it. It will allow future upgrades where the 1080 cannot.
    Also, it's cheaper here: https://www.hdavpro.com/ProductDetails.asp?ProductCode=RXA2080BL
  • mdaudioguy
    If a manufacturer's warranty is important to you, be sure to check their website to determine if a particular dealer is authorized. Manufacturers may not honor a warranty if purchased from an unauthorized dealer. Just something to think about. https://www.yamaha.com/paragon/dealerlocator/
    tonyb Posts: 33,072
    Couple things....
    How many actual Bluray movies do you watch ? Actual movies from a disc. Because if most your movie watching is off of cable/Netflix, all those bells and whistles isn't going to matter much.
    Wifi and BT can be added to any AVR, and personally, I would pick another stand alone unit to handle those duties better, more stable, than an AVR would.
    If music is important to you, you'll never make headway using a HT receiver for it.
    Make sure the receiver you get has pre-outs for an upgrade path with power.
    Also...no such thing as "future proof" in the world of HT receivers. We've learned that lesson a time or 2 already.
  • mrloren
    Go for the 1080 and get an SVS 12NSD sub
  • I’d get the 2080 if you can. It has a better calibration program, dual Sabre DACs, and a beefier amp. I bet you can find a deal and the difference in price won’t be that great.
    But the 1080 is pretty sweet too, either way, great choice.
  • Well, I just about pulled the trigger on the 2080-but it was $600 more than the 1080, 9.2 channel(which more or less was too much for my space) and it was two weeks out. SO, I did get the 1080! My first Yamaha component ever. HOPEFULLY this avr exceeds my expectations.
  • Congrats
  • Thanks, Jeremy, and everyone else who offered their knowledge. The Yamaha RX-A1080 will be driving my Polk TSx550t’s up front, Polk TSx250c center, and Polk TSx 110b’s for rear surround AND front heighth! I guess the only missing piece is a MODEST sub (preferably on the smaller side), which I’ve already gotten a few suggestions on. Thanks again, everyone.
  • mrloren
    Right now a modest sub is a not even a question
    https://www.svsound.com/pages/subwoofers
    Either one SB is more for music, PB is more for HT. They will do both very well.
  • Quick question about speaker placement. I have the speakers, as mentioned in earlier threads, for a 7.0 system (I’ll get a sub soon!) My seating position is directly aagainst the back wall of my theater room, so speakers behind me is of course not possible. I have a door on the side of the room, so side speakers aren’t really possible either. I have the two pairs of TSx 110b’s to use as rear surrounds and front heights. What is the best placement in my setup for the 110’s?
