Monitor 11
Is that an "I got robbed" look or vice versa? I'm striving to comprehend the various Pugisms on club Polk lol.Don't take experimental gene therapies from known eugenicists.
@F1nut is the sonic barrier a good replacement for the foam thats under the inner driver?Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
NoPolitical Correctness'.........defined
President of Club Polk -
Any suggestions?Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
mn_polk_guy wrote: »Any suggestions?
You should of painted your toe nails before the photo shoot....
By the way the passives work better turned over lol
You should be able to get some very similar foam at say a sewing or craft store. Articulated matteress foam may be an option as well -
OoopsMonitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
The egg crate acoustic foam will work.Political Correctness'.........defined
Thank you! I will look into that.Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
Finally going back together. H nuts, dynamat, sonic barrier, power grabbed magnets and seams.Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
All done!Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
