Need new central heat/AC
13»
  • rpf65
    rpf65 Posts: 2,127
    Yes. York and Coleman are owned by Johnson Controls.
    I don’t Presley care for either brand.
  • charley95
    charley95 Posts: 908
    I had that brand installed Heat/Air back in 2011. So far so good. An old retired HVAC guy I know installed it for $2900. The only drawback I've had so far is some kind of temp. sensor rod in the furnace unit. Not really sure what it's called but, I have to clean it annually. It's a straight rod about the diameter of a coat hanger. It gets corroded on the tip and I use sandpaper to clean it. If not cleaned the furnace runs continuously.
    Hopefully it will last till I sell and leave this miserable state in 6 years.
  • rpf65
    rpf65 Posts: 2,127
    That’s your flame sensor. Carbon build up needs to be cleaned off every once in a great while, but you shouldn’t have to clean it yearly.
    May want to get it looked at, just to be safe.
  • charley95
    It's actually been about 2 years since I've cleaned it. It's in such a tight area that it's easy to drop the screw that holds it in place. I usually don't mess with it if the furnace is functioning properly as it is so far. It's such a PITA to keep from dropping the screw which I'd never find. Any future problems I should be aware of with this brand?
    So far it's performed well. It's just louder than the old Rheem I removed that was installed in 1977.
    EndersShadow Posts: 17,535
    edited October 2018
    charley95 wrote: »
    Magnetic tipped screwdriver :smile: ... Saved my bacon on more than one occasion.
    Or one of these
