Connecting Computer (VGA) to 65 inch display (HDMI) sound not required
hoosier21
For work, I have to supply a wall mounted 65 inch display, and connect it to a computer that only has VGA out (1920x1080).
Any help selecting a converter would be appreciated.
Thank you
Russ
Thank you
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
In line converters are all over the net. Some are cables, others are stubby adapters. Just keep in mind that most ar one way in the wrong direction, so look for an analog cable without a box.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
FestYboy - I have seen so many choices, hoping for recommendation
Mikey081057 - wireless in not an option, Utility control room installation
DSkip - Desktop, SEL 3355 computer
To ask it anotherway, anyone know of a 65inch display that supports 1920x1080 with VGA input?Dodd - Battery Preamp
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
You cannot add/swap a video card with HDMI?
Some displays that size are really picky about resolution. They may have only a few native screen sizes that they will recognize and if your computer video software doesn't output the EXACT number of pixels, you would get no image.
If have tried a few cheap solutions with not so good results.They tend to need to be unplugged and plugged back in to facilitate an HDMI handshake each time. I can't name any particular brand names because they are somewhere in a box in storage where they belong. -
Thanks for the comments, I can not add a video card. I will figure something out.Dodd - Battery Preamp
Search "VGA to HDMI" on Amazon. Lots of choices under $20. Go with the most/best reviews.
I ended up buying a true 65 inch monitor with VGA input, thanks for your time guys.Dodd - Battery Preamp
I was under the impression that the tv/monitor was already in place. Your purchase fixes everything.
