Connecting Computer (VGA) to 65 inch display (HDMI) sound not required
For work, I have to supply a wall mounted 65 inch display, and connect it to a computer that only has VGA out (1920x1080).
Any help selecting a converter would be appreciated.
Thank you
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
  • FestYboyFestYboy Posts: 3,857
    In line converters are all over the net. Some are cables, others are stubby adapters. Just keep in mind that most ar one way in the wrong direction, so look for an analog cable without a box.
  • Mikey081057Mikey081057 Posts: 7,184
    edited October 2018
    Chromecast if you have wireless ethernet
    https://store.google.com/us/product/chromecast
    Garage | Polk Monitor 5B's
  • hoosier21hoosier21 Posts: 4,405
    FestYboy - I have seen so many choices, hoping for recommendation
    Mikey081057 - wireless in not an option, Utility control room installation
    DSkip - Desktop, SEL 3355 computer
    To ask it anotherway, anyone know of a 65inch display that supports 1920x1080 with VGA input?
    You cannot add/swap a video card with HDMI?
  • Viking64Viking64 Posts: 5,293
    Some displays that size are really picky about resolution. They may have only a few native screen sizes that they will recognize and if your computer video software doesn't output the EXACT number of pixels, you would get no image.
    If have tried a few cheap solutions with not so good results.They tend to need to be unplugged and plugged back in to facilitate an HDMI handshake each time. I can't name any particular brand names because they are somewhere in a box in storage where they belong.
    Thanks for the comments, I can not add a video card. I will figure something out.
  • mdaudioguymdaudioguy Posts: 5,137
    Search "VGA to HDMI" on Amazon. Lots of choices under $20. Go with the most/best reviews.
    I ended up buying a true 65 inch monitor with VGA input, thanks for your time guys.
    I was under the impression that the tv/monitor was already in place. Your purchase fixes everything.
Howdy, Stranger!
