Quad shield RG6 40ft RCA?
I know it is not ideal but would RG6 quad shielded ran only next to a heavily shielded HDMI cable be ok?
I want to move my amp and tube buffer to the front of the room to free up space in my in-wall rack for more toys. Plus it would allow me to use my Audioquest CV8+ speaker cables.
Thanks for any suggestions.
Welcome!
    yep
    Thanks Pitt, now if I can just find my RG6 to RCA adapters. :(:(:#:#
    you know you could just terminate the RG6 in RCA right?
    Yes, but I dont have any on hand. Was going to try and get it done today. Can't locate my rg6 crimp tool and stripper anyways. I have a feeling I know where they are but dont want to be in the garage right now. Very hot, humid and muggy today.
    Got it all done. Have a horrible ground loop. I've narrowed it down to the HDMI out from the Yamaha HTR to the TV. If I tinker with it at the Yamaha end the ground loop buzz goes away. Tried a Emotiva HDMI and now have a new Monoprice Hoss HDMI. Both are 40 ft and problem is the same with either cable.
    Always something right???? :s:s
    I think I may slice in more of my 10 guage Romex to the front of the room to feed the amp on and the rest of the equipment.
    I have a Belkin PureAV PF60 that is fed from a dedicated 10-3 or 10-4, I'm not sure but there are 4 wires and I have 2 of them to ground on a dedicated 30amp breaker. So maybe, I'll splice in and make an extra run to the Parasound amp at the front of the room.
    The RG6 as a RCA cable seems to work well.
    What tubes you running in the yaqin? Just curious?
    Ground loop, you have cable t.v. coming in somewhere?
    edited October 2018
    The Sylvania get the most use. I like them most. I also have the OEM tubes that came with it. The RCA tubes run extremely hot.
    edited October 2018
    Nice i have many many tubes. I do have two pair of them GTA's mine do not glow that bright. FYI you can also run 6BL7 and 6BX7 in that as well. I bought some triple mica 6BL7's gta's from Brent Jesse man they work great. I do not keep my cages on because its a biotch to get tubes in and out with in place. Love my buffer!
    I've spent a ton more on tubes than my buffer cost. :D:D
    I just bought some Raytheon VT231 built in 1949 boxed and shipped to the military in 1950. They never seen the light if day until 2 weeks ago new old stock all the way. I'm using them right now.
    Mine is having an issue right now. I think there is a loose ground inside the transformer case. When I took it apart to put in new Clarity caps I removed a screw and could not get it back in and now I hear something moving around when I shake it. This thing is a PITA to work on.
    I either had the Chinese or the RCA TUBES in there when I took the picture. My Silvainia tubes are chromed so they dont glow that bright either.
    What is the consensus on KEN-RAD tubes?
    I also love this buffer.
    edited October 2018
    Clarity caps are too big no? 630 v is way to large man. You need 200v or less. The auricaps mod just barely fit. I thought about it but have so far decided to not do yet... yet key word because there are only a few caps that will fit.
    Ken-Rad tubes are the shiite. Very hard to get good sets without paying nos 5692 prices. I'd go 5692 before i spent that kind of money on Ken-Rad's.
    Tung-Sol's American made are very good. I can give you some good ideas and send pictures if you want.
    edited October 2018
    If you off set one like I did in that first picture they fit fine. I could not find any other Clarity caps for the UF I needed.
    Other than physical size is there an issue using the 630v cap? I could have sworn the stock cap were 630v or so.
    No not at all. I was thinking they were much lower voltage.
    Here is some reading
    http://forum.polkaudio.com/discussion/145315/yaqin-cd3-darkvoice-336se-mods-coupling-caps
    I'll research more later been years since i thought about it.
    I think that was the thread you linked me to when I did the recap.
    Do you think it's worth while to replace the power supply caps with Nichicon Gold Tune? At least I think they are power supply caps.
    Your call. I like those Nichicon fine gold or KG muse and Elna silmic II. Of course size plays a huge factor in which ones you use
    So FYI for anyone needing long rca runs. The RG6 is very well shielded and I am not noticing any I'll effects at all. No buzz or hum. Seems to work pretty good.
Welcome!
Welcome!
