Setting up a subwoofer for 2.1?
mdaudioguy wrote: »
Idk, but around $450 new online. Sold for $700-$800 in the past year. Some used on eBay under $300, but who knows what you get there.mdaudioguy wrote: »I decided to get a new sub and shift the little Sunfire to HT-only duty. The more I listened, the more I noticed it just wasn't as musical as I had hoped. It has great output for its size, but only in what seems to be a narrow range. Since my hybrid system is biased towards 2-channel, the Sunfire gets demoted. Also, this will allow me to dedicate one sub to HT LFE duty.
Next sub up for 2-channel... a Martin Logan Dynamo 700w. I've set several of these up for others and have always been impressed with this 10" down-firing sealed box. Since they've recently been discontinued, they're currently available at a ridiculous price.
Although it comes wireless ready, I think the line inputs will be better for 2-channel performance. This sub seems like it should supplement my bookshelf speakers nicely.
A couple of oddities - a non-stop bright blue flashing LED on the back when not connected wirelessly. Seriously, this thing doesn't give up. Also, it comes with spikes - that get inserted into the rubber feet. Yes, these spikes decouple! I'll use it this way for a while, but eventually, I think it will benefit from proper spiking.
What's a good price on those Martin Logan subs on the used market? Maybe I'll follow your lead.
Thanks, I'll take a peek locally
*Comes back 3 days later* Hey guys, look what I just picked up for $30... -
mdaudioguy wrote: »
$30???? Do tell. -
codycatalist wrote: »mdaudioguy wrote: »My integrated has pre-outs for subwoofer connection. At the moment, I just have a single RCA sub cable connected, but I'm thinking two would be better. Any suggestions for a PAIR of decent sub cables? Maybe 2 meters in the $100 range?
Is two better though or does it not make a difference? I always wondered but just went with the flow.
*Edit* I read that the preouts are usually set to output mono so it wouldn't make much of a difference, that is unless yours is different. Maybe the manual of the integrated would clarify.
To be clear, these are not dedicated subwoofer outputs, like an AVR has, but true L&R pre-outs. So, yes, I'm shorting myself with just one cable. The sub is only getting the low end from one channel. I need two cables. -
And, it's pretty clear the little Sunfire is getting demoted again. It can't do HT justice, even in a hybrid rig where HT is priority #2. Our workout room has a TV with Polk in-walls that could use a little help. The only question is, another Dynamo 700, or its bigger brother, the 12" 1000?
mdaudioguy wrote: »mdaudioguy wrote: »
$30???? Do tell.
Typical @la2vegas purchase -
mdaudioguy wrote: »
Surprised to see no toe-in on those speakers. -
I've got the fix for that.Political Correctness'.........defined
President of Club Polk -
$30???? Do tell.
Ah, gotcha! I didn't read the sarcasm, and was wondering where I might snag one for that, or what kind of condition it might be in, for that matter...
mdaudioguy wrote: »
I've only briefly experimented with toe-in, with missed results. There's an existing imaging issue with the right speaker being only one foot from the side wall, while the left is in a more open space. I have a couple of 2x2 acoustic panels I want to experiment with first, before I mess with positioning. -
Why not build a small platform for the smaller sub and paint it black so it would blend in more making the two subs the same height.
Geez... it is and has always been available....... Right next to the unicorns!
