Yep, This is happening!!!
    pitdogg2 Posts: 27,168
    delkal wrote: »
    Would something like this void the oppo factory warranty on anything?
    I thinking if you have loading and drive problems under factory warranty time frame.
    You are assuming there is still a warranty. Last I heard OPPO is done with and they contracted with a third party for warranty claims. I don't think anyone knows what that means yet. And I hope they have the repair parts.
    Aren't you a buzzkill. Last i read oppo was going to still support their products including all firmware needs.
    nooshinjohn Posts: 25,955
    delkal wrote: »
    This is what Oppo told me as well. They are not marketing them any more, but are not going out of business.
  • Emlyn
    Emlyn Posts: 4,786
    Oppo sent out a new firmware update for the 205 at the end of June and said they would continue to provide periodic updates.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    delkal wrote: »
    They're one of the bigger mobile phone manufacturers in the world, so still a viable company.
  • delkal
    delkal Posts: 764
    edited October 2018
    Sorry to be a buzzkill but here is an older article from Forbes. Not sure if anything changed but it was clear at the time that Oppo was cashing out (or taking the money and run?) and letting a third party be responsible for warranty work. They are supposed to keep giving software updates but for how long who knows.
    "The tech support, warranty, servicing and spares business will apparently be handled by an as yet unnamed third party. It's also worth mentioning that Oppo's mobile phone business is unaffected by the announcement."
    https://forbes.com/sites/johnarcher/2018/04/02/oppo-shock-popular-av-brand-announces-that-its-time-to-say-goodbye/#4376fcd83acc
  • Emlyn
    Emlyn Posts: 4,786
    That Forbes article was updated with more recent information and commentary from Oppo and Cambridge Audio indicating their ongoing firmware support and collaboration with Mediatek which does most of the work on the 4K platform. Sony, and probably others, continue to use the Mediatek platform for 4K players.
    Toolfan66 Posts: 18,125
    Maybe this will help kill the buzzkill..
    While I hesitate to recommend any unit you cannot audition beforehand, Modwright takes the risk out of owning its modified Oppo, Although the factory warranty is voided, Modwright offers a one-year warranty of its own and offers to service the unit should it fail in a way that would otherwise be covered by the factory warranty, for cost of parts alone. Because the Oppo is so reliable, this is “very seldom necessary,” according to Dan. Even Oppo’s Jason Liao praised the workmanship of the Modwright modifications as “exceptional.” One rarely hears this kind of praise about any modification from the manufacturer of the original equipment.
    One of my audio buddies and a frequent listener to my system said that he thought that I was playing my turntable when the Modwright-Oppo was in the system. I must admit that there were times when I was so lost in the music that I had to look up to see which source was playing. That is very high praise and has never happened to me before with a digital source in my home.
    Conclusion
    So are the Modwright “Truth” modifications to the Oppo player worth the cost and the risk? The answer to that question is a resounding, “Yes!” The build-quality is exemplary and the sonics are exceptional. It is the first digital player I have had in my listening room that didn’t make me want to go back to my analog rig right away, and that’s because it sounds so much like analog in many respects, without giving up the bass extension and control, clarity, fine detail resolution and retrieval, and convenience that can make digital so attractive. With outstanding sonics that can make you forget you’re listening to digital, and its remarkable flexibility and compatibility when playing discs from a player or a computer-audio setup, I suspect this is one universal player that you’ll be hanging on to for a long time. While I’m unwilling to abandon my analog rig, I can see why others, like Arnie, have chosen to do take this path, particularly when one feeds the Modwright-Oppo first-rate, high-resolution source material. The Modwright Oppo is now my digital reference.
    That is just part of the article....
  • mdaudioguy
    Do it, and don't look back!
    SCompRacer Posts: 9,121
    edited October 2018
    Congrats.
    I've owned the Signature Truth ModWright Sony 999ES and Sony 9100ES. 5687 tubes, tube regulated PS. Good stuff. Also had a couple of his pre amps, SWL 9.0SE and the SWLP 9.0SE, the P being built in tube phono.
  • stretchl
    stretchl Posts: 1,334
    edited October 2018
    Here’s the question, even assuming that the warranty suddenly disappeared into the ether (which I don’t believe it has): Does the vanishingly remote chance of the need to file a warranty claim negate the value/desirability of the unit, any modifications notwithstanding? The answer is clearly, “no.” I can’t remember ever having to have had warranty work done on any electronics purchase, and certainly never have done so for hifi gear. I’m sure I’m not the only member of that group. This debate over the warranty is much ado about nothing.
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
    gudnoyez Posts: 8,172
    Looks like a great upgrade, will you be using this for audio only? How does this Mod Wright upgrade improve viewing 4k content?
    gudnoyez wrote: »
    Yes I will only be using this for audio only, the upgrade is for only audio as well..
    That's what I thought, good thing you have a second one then for viewing 4k material. Enjoy.
    mhardy6647 Posts: 35,149
    Major, major modifications that, if well implemented, could be very substantial improvements... although one could debate the value of vacuum tube vs. solid state power supplies 'til the cows come home ;)
    gudnoyez wrote: »
    You can still use the player for all functions.. But yes the one in my HT will stay stock..
  • steveinaz
    steveinaz Posts: 19,545
    I think I have a woody.
    steveinaz wrote: »
    quick go find Bev!! Like rain in Arizona it only happens twice a year at your age :D:D
    OPPO is on the bus headed to ModWright!!!! Picked up about an hour ago..
  • stretchl
    Did u use greyhound’s shipping service. I’ve never used it. How much does it cost and how convenient (or not) is it?
    - Isaac Asimov
    Hi-Fi
    Visuals
    Viking64 Posts: 7,590
    steveinaz wrote: »
    :p
